 Hyundai-Forums.com > Hyundai Models > Scoupe Forum > How Can I Push The Speed Of The Car Past Stock
 How Can I Push The Speed Of The Car Past Stock, speed
tomlin19
post Nov 20 2007, 03:28 PM
Drives: 1992 Hundai Scoupe 1.5l
Status: OFFLINE
i have a 1992 scoupe, it is stock, i was driving down the interstate and it wouldnt go past 81 mph. is that the stock speed of the car? and how can i increase the speed.
User is offlineProfile CardPM
QuoteReply
byronguidry3732
post Nov 20 2007, 06:38 PM
Group Icon
Group Icon
Group: Super Mod
Status: OFFLINE
Dear Tomlin,
Per the 1992 Scoupe owner's manual, your speedometer tops at 100 mph/160 kmph. The car is 15 year's old. The 1992 Scoupe only had a 1.5 liter SOHC engine.
How many miles do you have on this engine? Does it have visible gray smoke on startup? How about on a cold day below freezing? Smell like burning oil? Oily residue in the tail pipe?
What exactly is your compression on each cylinder? Realize that 100-110 psi is normal. If your engine measures in the 70-80 psi range, be glad that you can do 81 mph. Be glad that it starts!
How can you increase the speed? Swap out a 1.8 liter Beta or a 2.0 liter Beta II engine.
That is, I am ASSUMING that your timing belt is not worn past scheduled replacement, has broken off a few teeth, and skipped time. In which case, replace your timing belt before it slips time worse or breaks.
Byron
QuoteReply
tomlin19
post Nov 20 2007, 08:59 PM
Status: OFFLINE
there is about 94048 miles on the original engine. yes there is grey smoke coming out of the tailpipe at start up. it starts fine in those temps. no burning oil smell i think. no oil resedue in the pipe.
there is about 94-98 psi, it fluxuates. it starts.
oh i checked the timing belt and it looked odd so i replaced it when i first got it. also i changed the other 3 belts.
oh and changing the engine is out of my budget.
QuoteReply
TPA
post Nov 21 2007, 09:10 AM
Drives: Scoupe 1.5 GT 25 special 1993
Status: OFFLINE
think somethings wrong, topspeed is 170 kp/h. Have driven that with my old 1990 scoupe (167000 km)
QuoteReply
simisker
post Dec 13 2007, 02:14 PM
Drives: Scoupe, 1995, 1.5 turbo
Status: OFFLINE
wat does the grey smoke mean on startup?
QuoteReply
byronguidry3732
post Dec 13 2007, 03:56 PM
Group Icon
Group Icon
Group: Super Mod
Status: OFFLINE
QUOTE(simisker @ Dec 13 2007, 03:14 PM)
A little white smoke on startup on a cold day means water vapor is condensing.
Bluish, grey smoke means the car burns oil...and how soon before the bluish grey smoke disappears tells you how badly the piston rings are worn. the exhaust also has a distinct burned oil smell, and leaves an oily residue in the tail pipe.
Dense white smoke that has a sickly sweet smell to it and continues after the first minute of running means you have a blown head gasket.
Byron
QuoteReply
Mr Coupe
post Dec 16 2007, 05:07 PM
Drives: 1995 Hyundai S Coupe LS 1.6L
Status: OFFLINE
QUOTE(byronguidry3732 @ Dec 14 2007, 07:56 AM)
Byron
my car I am told has some blue smoke on startup.. but when it heats up its fine.. i doubt mine is piston rings.. also my lifters are worn (they tap) how much do you think it will be to replace..?
QuoteReply
evotistical
post Dec 16 2007, 11:54 PM
Drives: 1991 Hyundai Scoupe, 2 Suzuki Renos
Status: OFFLINE
QUOTE(tomlin19 @ Nov 20 2007, 01:28 PM)
4g63T swap FTW :460:
What part of the USA are you in?
This post has been edited by evotistical: Dec 16 2007, 11:55 PM
QuoteReply
hugamuto
post Dec 30 2007, 05:48 PM
Expert
Drives: 2008 Sonata V6 5 A/T Gulf Spec
Status: OFFLINE
81 mph would be about right for a 15 year old scoupe, if you really want to go fast you should get mitsu 4g63 engine swap and maybe turn the boost up a bit that will easily get you beyond what your speedometer has listed as its maximum. Good luck :beer:
QuoteReply
> Link To Us
> Similar Threads
Speed Sensing Auto Door Locks
Forum : 4G (2007+) Elantra
aaronwt 2,697 24 Today, 05:26 PM
By: CapHwys
Belt Squealing When I Turn Car On, Turn Ac On
Forum : 2G (2000-2005) Accent
calebp 80 2 Today, 12:31 PM
By: JBimmolate
Car Waddles
killian86 21 2 Today, 12:26 PM
By: JBimmolate
Stock Internals I4
Forum : GK Tiburon (2003-2008)
Tiburon_03 26 1 Yesterday, 10:40 PM
By: Tiburon_03
Slight Pause When I Turn On My Car.. Stater Going
Forum : Performance
mar_1998 12 0 Sep 2 2008, 11:14 AM
By: mar_1998
5th September 2008 - 06:30 PM
