2 Pages V   1 2 >
> Fog Lamp Modification, now I can do this!!!
nate704
post Oct 4 2007, 11:57 AM
Drives: Arctic White SE V6
US version sonatas can only turn on the fog lamps when the head lamp is turned on, and when you flash or hi beam, the fogs are off.
BUT, Korean version sonatas can turn the fogs without turning on the head lamp.
We do have DIY fog lamp conversion, but we can't control the fogs with the switch.
So, I finally did the DIY conversion, and I can start using my fogs more often :banana:
I will post pictures by this evening.
BTW, I already lost two white plastic trim pins~! LOL
wymi
post Oct 4 2007, 01:16 PM
Drives: Mine: 2007 Sonata Limited Platinum Edition Her's: 2007 Sonata GLS I4
I am going to use the factory relay and just control the coil on the relay with the marker light positive wire. That way anytime the marker lights are on the fog lights will also come on.
mamamia
post Oct 4 2007, 01:32 PM
Drives: 2006 Arctic White Sonata GLS 2.4 (DOB 11.7.05, on my BD!)
Mine are on permanently, also functioning as DRL during the day. Was done by a professional.
wymi
post Oct 4 2007, 01:59 PM
QUOTE(mamamia @ Oct 4 2007, 01:32 PM)
[right][snapback]112102[/snapback][/right]
I saw that mod, I only want mine to come on when I switch them on.
This post has been edited by wymi: Oct 18 2007, 08:40 PM
nate704
post Oct 4 2007, 03:08 PM
maybe someone with an electrical tape and wire cutter! :bwekk:
dcjwlee
post Oct 4 2007, 03:13 PM
Expert
Drives: 2006 Hyundai Sonata
QUOTE(mamamia @ Oct 4 2007, 02:32 PM)
So you couldn't turn em off if you wanted to? I guess thats what permanent means lol.
This post has been edited by dcjwlee: Oct 4 2007, 03:13 PM
nate704
post Oct 4 2007, 03:32 PM
The permanent method is already posted HERE
, and it doesn't require any professional ASE certified technician to do it at all. :P
it's actually easier than replacing head lamp bulb.
I didn't like the way of turning the fogs on permanently without any controling method.
wymi
post Oct 4 2007, 03:41 PM
QUOTE(nate704 @ Oct 4 2007, 03:32 PM)
[right][snapback]112148[/snapback][/right]
So what did you come up with to turn them on? What do you think of my idea?
nate704
post Oct 4 2007, 06:28 PM
This post has been edited by nate704: Oct 4 2007, 06:29 PM
Attached File(s)
wymi
post Oct 4 2007, 06:31 PM
Nice job! Tell us how you did it. Did you change your low beam bulbs?
This post has been edited by wymi: Oct 4 2007, 06:33 PM
nate704
post Oct 4 2007, 08:07 PM
Post #11
Yup.
My low beams are converted to HIDs.
and for the fog lamps,
1. you need to take the driver's side lower crash panel and steering wheel column covers off.
2. Find a connector that has a wire that connects the fog lamp switch and dimmer/passing switch.
3. Cut the wire and ground the wire from the fog switch.
4. pop the hood and locate the fues box.
5. there's three bolts holding the fuse box to the connectors at the bottom of the fuse box.
6. unbolt the bolts and disconnect the fuse box from the big three connectors at the bottom of the fuse box.
7. locate the connector that has a wire that connects the fog lamp relay and head lamp low beam relay.
8. cut the wire and connect that wire to the left side marker lamp wire.
9. turn the parking lamp only and you enjoy your fog lamps turned on
wymi
post Oct 4 2007, 08:27 PM
Post #12
Thanks for the info. Could you be more specific with wire colors and locations? Can you still use the fog lamp switch to operate the fog lights?
CCH
post Oct 4 2007, 08:32 PM
Post #13
Drives: 2006 Hyundai Sonata GLS V33
Nate, what if you connected the wire to a ignition on power supply instead of the marker lamps? Would this allow the fogs to be controlled independent of any other lights. Do you think this would work?
nate704
post Oct 4 2007, 11:07 PM
Post #14
yes, you use the factory fog lamp switch to control the fog lamps.
And yes, it you connect the wire from the fog lamp relay to ignition, you can have complete control regardless of headlamp switch position.
for example, if you start the car, you can turn the fog on without turning the parking lamp at all.
I hooked up the wire to the side marker lamp because I wanted exact same setup as korean version sonatas.
This post has been edited by nate704: Oct 4 2007, 11:28 PM
Attached File(s)
Attached File  foglamp_circuit_with_instruction.jpg ( 124.65K ) Number of downloads: 260
wymi
post Oct 5 2007, 06:20 AM
Post #15
nate704, thanks for the detail info. Can you point me to where you got that diagram?
wymi
post Oct 5 2007, 08:15 AM
Post #16
QUOTE(CCH @ Oct 4 2007, 08:32 PM)
[right][snapback]112185[/snapback][/right]
Ah, brilliant, I will try this after doing the under dash wire cut and apply to ground mod. Ignition on will be easy to use in the under hood fuse box, I've already tapped in to an Ignition on wire in there for my Radar connection.
UWISHU1
post Oct 5 2007, 09:11 AM
Post #17
Drives: 2006 SONOTA LX 3.3
great info Thanks for sharing :)
CCH
post Oct 5 2007, 08:23 PM
Post #18
Awesome, thanks nate for the info.
UniR
