> 95 Starting Problem
hmglauj
post Jan 16 2005, 09:57 PM
Drives: hyundai accent
new starter, new altinator, new battery, checked all the fuses and still it wont startup...someone help me out....nothing happens when you try to start it, no sounds, no turning, no nothing....help me outs guys, 95 accent auto
soullink
post Jan 19 2005, 03:41 AM
Group Icon
Group: Moderator
Drives: Hyundai Accent MVI - 1999, 1.5i, 16 valve - www.soulaccent.com
The only thing I can suggest is to check the wiring. A fault with the immobolisor will allow the starter to operate - but the engine won't start.
When you say "no nothing" - do you mean you don't even get any lights on the dashboard ... and can you get the main lights to come on.
This is becomming a bit of a favorite fix to suggest to people with these sort of problems - but it's worth a try, so here we go.
Basically if you car is totally dead check the battery is charged and the positive and negative terminals are securely connected. Then check that the earth lead from the battery is connected correctly and securely to the chassis of the car (and is not corroded) - it helps if you have a multimeter to do this ... set it to "continuity" - should beep when you touch the pins together, then put one pin on the battery negative terminal, but not the lead, and the other lead to any piece of bare metal / screw / bolt attached to the chassis. That will conform the battery negative is ok (a resistance check is also useful as there may be a high resistance indicating bad connections).
Using the same proceedure as above (with one lead on the battery negative), touch the other lead onto the engine casing and then the starter motor casing to see if they are earthed correctly.
I'll leave it there for now - let us know what the results are and we'll go from there, but these kind of problmes are hard to diagnose over the internet so I can't promise any results. Good luck!.
hmglauj
post Jan 20 2005, 02:04 AM
i'll try when i get a chance, any other suggestions guys??
VALKYRIE YB70
post Jan 20 2005, 02:37 AM
Mod Emeritus
Drives: Modified (180 b.h.p.) `95 Hyundai S-Coupe Turbo SE ....Sadly now sold & replaced with an `04 Alfa Romeo 156 2-litre Veloce! :-http://aol.photobox.co.uk/album/thumbnails.html?c_album=7089276&page=all
A mobile mechanic/auto electrician will find the fault in minutes!.
Nick.
No New Posts Starting Car Up
6 jj8900 84 19th November 2008 - 06:06 AM
Last post by: cmerica
4 Osaka 187 17th November 2008 - 09:24 PM
Last post by: mrstats
No New Posts Topic has attachments95 Talon Tsi Awd Shell
2 eclipsed95 52 14th November 2008 - 08:03 PM
Last post by: eclipsed95
No New Posts Problem Starting
H-1 tourismo
0 ricky1947 17 8th November 2008 - 12:45 PM
Last post by: ricky1947
No New Posts 950hp Porsche Gt3 Rs Turbo
0 trev0006 132 31st October 2008 - 06:43 PM
Last post by: trev0006
23rd November 2008 - 12:26 PM
