hey everyone.. i have info on the tiburons.. i had a problem on my car not starting. ive delt with this in other cars b4 simple.. well first thing. check your coil.. if your coil is still good then you have to check your CRANK SHAFT SENSOR.. your coils will not fire with a bad crank shaft sensor. my coil i less then 6 months old and my car would not crank up last nite. so this morning i went out there and pull my sensor out. mine wasent bad but there was some gunk on e sensor. clean it off and BAM!!! fired right up.. keep that oil change up and you shouldent have a problem with your sensor.. so if theres no fire be sure to check thses things..
COILS.... CRANK SHAFT SENSOR... CAM SHAFT SENSOR....(have had a problem with these.)
if your car has no fire one of these are bad...
let me know your out come.. thanks
