In Australia we refer to Gas as Petroleum, if that's what you are referring to. Anyway My 2000 Accent Gs emitts a series of knocks and loud bangs when ignition is switched off, mostly until car cools down. Not sure what the issue is with the Polycarbon-alloy fuel tank, but dealer can not seem to diagnos? As no other faults are active.
In your case mate sounds like a blocked fuel system or contaiminated fuel ??? Possible recommendation, in Australia Shell has released an Optimax fuel with 95 percent octane and clean agents to flush the fuel system, you should try it and see what happens after that !!!!
Good luck.
