 Hyundai-Forums.com > Technical > Interiors and Exteriors > Cloudy Headlamps
 Cloudy Headlamps
whicky1978
post Sep 12 2007, 09:54 PM
Drives: 2001 Hyundai Elantra GLS
Status: OFFLINE
I have cloudy headlamps, they have been like that since I bought my car two years ago. I took one off, and I tried to take it apart, but found out that they were sealed tight. Long story short, I broke the seal, and now water gets in, even thought I tried to seal it with marine glue. From what I read, I have to replace them $150 to $200.
So, what causes the cloudiness? If I by new lamps, will they turn cloudy too?
I like the bananna :banana:
User is offlineProfile CardPM
QuoteReply
Bdiggy
post Sep 12 2007, 10:40 PM
Drives: 2004 Hyundai Elantra GT 2.0
Status: OFFLINE
The protective layer has worn off the plastic and they are vulnerable to cloudiness and scratch easier. There are restore kits you can buy at Auto Zone or stores like it for around $15 and after you do that you can use Mcguires plast-x to keep em' clean. As for the crack you put in the seal, I'm not sure. To get those apart you have to "bake" your head lamps to soften the glue enough to seperate the lens from the housing. Perhaps if you heat the leaking one and let the glue reharden it will seal itself again. Not sure. Other than that i'dsay search ebay for a new one. You can find them cheap there. Good luck.
Here's a link on how to seperate the lamp. (step 2) If you like, search this site for a possible solution as it concentrates soully on 01-06 Elantra (and on the newer HD a little bit)
http://www.elantraxd.com/DIY/headlight.php
This post has been edited by Bdiggy: Sep 12 2007, 10:44 PM
QuoteReply
whicky1978
post Sep 13 2007, 04:23 PM
Status: OFFLINE
Thank you, my cloudiness is on the inside.
QuoteReply
TOOSLO
post Sep 17 2007, 12:18 PM
AMSOIL T-1 CERTIFIED DEALER
Drives: 2007 hyundai accent gs 3dr auto
Status: OFFLINE
CLR
Bdiggy....pretty much summed it up....
you can use the products on the inside once you get it apart...take your time and be very careful when "baking" ,seperating, and resealing....dont rush it.
i have had similar issues with my sentras in the past and had great results.
QuoteReply
Bakesalee
post Sep 24 2007, 07:34 PM
Drives: Sonata 2003, 4cyl
Status: OFFLINE
Don't take it apart! Check this link out:
http://meguiarsonline.com/forums/thread/28360.aspx
I can vouch for this, I did it last Sunday. Wet sand (dip wetordry 1000 grit into water), spray headlights with water, keep em wet, sand headlights for at least 10 minutes. Then repeat with 2000 grit. Then polish them for 20 minutes a piece. I did this last Sunday and saved roughly $300 by not buying new headlights. If you have any questions.
QuoteReply
Bdiggy
post Sep 24 2007, 09:26 PM
Status: OFFLINE
^^That's great but the fog is apparently on the inside so the lamps do need to come apart.
QuoteReply
whicky1978
post Sep 25 2007, 06:00 PM
Status: OFFLINE
Well, I got the headlamps apart, but many of the peicies connected to it started to melt. , so the headlamps didn't fit back perfectly, and the clips broke. Also, it turned out that the cloudiness was on the outside.
I sanded wit 1500 sand paper and used McGuires, if I could go back, I probably do it the Bakeslee reccomends. I sprayed painted the interior too.
If I had to do it over, I would have not have preheated my oven to 350 F, but 200 and make leave it in their longer. A hair dirver might do the trick too. The DIY article did not mention if the oven was preheated..
I tried another idea also, but it was real dumb :blink: I tried cleaner my lights with paint thiner, but it dried out the headlamp and made it white, so now I am left needing to by two.
QuoteReply
> Link To Us
> Similar Threads
Dingy Headlamps
Forum : 1G-3G (1989-2005) Sonata
xx_ph4nt0m_xx 108 4 Sep 2 2008, 08:41 AM
By: xx_ph4nt0m_xx
Headlamps
Forum : GK Tiburon (2003-2008)
Tiburon_03 368 11 Jul 28 2008, 04:14 PM
By: rcetiburon03
How To Clean Inside Of Headlamps?
Forum : Grandeur & XG Forum
85_305 206 4 Jul 11 2008, 03:29 PM
By: 85_305
Head Lamp Cloudy
Forum : Trajet Forum
smedy14 249 3 Jan 22 2008, 08:38 PM
By: Bdiggy
Euro Dezign Headlamps?
Forum : 3G (2006+) Accent
DWFan 396 8 Aug 28 2007, 11:28 AM
By: DWFan
8th September 2008 - 01:53 PM
