> 1991 Hyudai Excel (4 Door), repeated turnover & rough running
Aeurix
post Jan 15 2005, 10:56 PM
Drives: Ohio
I recently had my (up until now) very reliable 91 hyundai excel die on me. I took it to a shop and they took a week to fix it-- and end result was it just needed a tuneup. The original problem was that it would start up, but then die out when i gave it any gas. They fixed that fine-- that was a week ago.
I tried to start it up this morning and the engine just turned about 10 times. I let off, gave it a minute, then tried again. After about 10-15 attempts and waiting, it kicks in. I figured it was probably a fuel injector problem , or maybe that water got in the gasoline mix somehow and was causing the gas/air ratio to be offset, so I went to the local gas station and got some "fuel enhancer" (STP, like Heat) to clean it out. I tried mixing it in, but it didn't start for a little bit-- then eventually after 10 times it started up (so i ran it around the block, and on the highway, etc.) It was a very very rough ride-- and when I go to let off the gas at all, it jerks and sputters, sputters but doesn't die, so I pretty much have to have the clutch disengaged or the gas fully on (partially and it goes berserk).
The car place took a week to fix the original problem (tune-up only? dunno), where they replaced all spark plugs, wires, and fuel injector. What is my current problem? I'm out of ideas.
thanks,
-Geoff
Dr. Hundi
post Jan 16 2005, 06:13 AM
Group: Mod Emeritus
Drives: Cressida
So i take it that the car is still playing up?
When was the timing belt last replaced???
Aeurix
post Jan 16 2005, 08:54 AM
Drives: Ohio
QUOTE(Dr. Hundi @ Jan 16 2005, 07:13 AM)
[right][snapback]4914[/snapback][/right]
Yes the car is still giving me a lot of trouble. I'm not sure when the timing belt was replaced last.. what makes you ask about the timing belt? Just curious,
-Geoff
skyclone
post Jan 16 2005, 10:22 AM
Drives: 88 Hyundai excel
Its possible a weak timing belt could have slipped a few notches and the engine would definately run rough. On the other hand you said they replaced plugs and wires but what about the cap and rotor? Did car run rough after wet conditions like wet snow or rain. It could be several causes .It doesn't cost much for a cap and rotor so try replacing those and see if it helps. If that doesn't work then a computer diagnosis may be in order. Problems like these can sometimes very difficult to diagnose. Good luck!!
Aeurix
post Jan 16 2005, 10:53 AM
Drives: Ohio
Thanks for all the help, i really appreciate it.
One thing it's doing which i can't put my finger on-- it randomly pulsates. The engine will rev up, then almost die, then rev up and repeat. It only does this when I'm stopped at a light or stop sign.. I'm not sure if there is any 1 thing broken that will cover all the things not working atm.
It's been pretty wet and cold the past few weeks, I'm pretty sure that's what caused the breakdown-- just can't pinpoint on which part (or which part(s)).
thanks,
-Geoff
Aeurix
post Jan 16 2005, 12:13 PM
Drives: Ohio
Aww shoot. Now it won't start up-- it just turns and turns. It sounds so much like a STARTER problem but they said they checked that all in the tuneup. hrmmm
-Geoff
Dr. Hundi
post Jan 17 2005, 02:16 AM
Group: Mod Emeritus
Drives: Cressida
If the engine was running rough, then began to hunt (idle up & down), now it doesn't start, I would be removing the timing cover and check your cam timing!
No New Posts Excel 93 Mass Air Flow Sensor Problem
do I need the mass air flow sensor?
0 lsotto2005 69 6th November 2008 - 12:03 PM
Last post by: lsotto2005
No New Posts Door Sill Paint Problem
Paint scratches on VC door sills
5 fadolfa 206 30th October 2008 - 11:53 AM
Last post by: LilBean
No New Posts Doors, Windows And Stero!
I'm at my witsend here!
1 Mickey_79 337 27th September 2008 - 06:48 PM
Last post by: promocom
No new Door/seatbelt Chime...
has anybody located the speaker?
32 devin6687 1,801 27th September 2008 - 05:20 PM
Last post by: craigdtx
No New Posts Excellent Service!great Dealership!
Above and beyond commitment!!!
6 Tango2Go 189 26th September 2008 - 01:28 AM
Last post by: Tango2Go
23rd November 2008 - 12:19 PM
