:00000732: glr!
First, you need to diagnose the problem. Get a second person to ride with you.
Empty the glove box. Road test for noise.
Still there? Open the glove box, inspect behind it for any loose objects. With the glove box open, road test for noise.
Still, there? Get under the dashboard with a flashlight, a 10 mm socket driver, and a phillips #2 screwdriver. Tighten every bolt and screw you can see.
Still there? Take your second person with you to the dealer, and take the service writer on a road test for noise.
Byron
