 Hyundai-Forums.com > Hyundai Models > Trajet Forum
> Screeching Belts And Dimming Lights
nick31
post Aug 29 2007, 05:17 AM
Drives: 2002 Trajet 2L Petrol
Ive had a Trajet for a month now and am a bit concerned about a few things:
1) there is an occasional screeching from the engine, usually when starting up but sometimes also when taking off in first. Sounds like a fan belt or something ? Does this need to be looked at ?
2) more worrying, the main beams have dimmed considerably while driving. They go dim for a few seconds, then bright again. What could be causing this ? (Im not switching anything on in the car that would cause them to dim and was driving at a constant speed when it happened.)
Any advice ?
This post has been edited by nick31: Aug 29 2007, 05:18 AM
trajetXG
post Aug 29 2007, 05:57 AM
SUPER MODERATOR
Group Icon
Group: Super Mod
Drives: 2003 Trajet, 2008 Santa Fe CM
Try spraying some WD40 while the engine is running. If still perceive, replacing the belts is the only way.
Time to replace your bulbs...
Any advice ?
montego
post Aug 29 2007, 11:49 AM
GLOBAL MODERATOR
Group Icon
Group: Super Mod
Status: Online
Drives: XG's (2001&2002)
if the alternator drive belt is slipping it will not be charging the battery as it should, tighten up the drive belt or replace it with a new one if it's worn, also it would be a good idea to get the alternator charge rate checked to make sure the voltage regulator is not faulty
wilson46
post Sep 6 2007, 02:26 PM
Drives: hyundai trejet gsi 2Lt
Hi new at this.
Screeching from my engine cured by oiling jockey wheel on fan belt discovered this after having all 4 belts changed, be carefull not to over do it dont want oil on the belts.
nick31
post Oct 5 2007, 08:16 AM
QUOTE(trajetXG @ Aug 29 2007, 11:57 AM)
[right][snapback]105369[/snapback][/right]
I thought the bulbs either worked or didnt. Can they be faulty ie; go dim then bright, without actually blowing ?
montego
post Oct 5 2007, 11:51 AM
GLOBAL MODERATOR
Group Icon
Group: Super Mod
Status: Online
QUOTE(nick31 @ Oct 5 2007, 01:16 PM)
[right][snapback]112255[/snapback][/right]
yes they can be dim if your alternator and/or battery is faulty
nick31
post Oct 10 2007, 05:53 AM
yes, but my point is replacing the bulbs as was suggested above surely wont cure the problem ?
whiterabbit
post Oct 10 2007, 05:30 PM
Drives: trajet gsi 2ltr auto
No replacing the bulbs wont sort the problem out , it sounds like you have either a faulty battery or alternater best thing is to get them both checked out .
Cheapest thing to do is look at the alternator belt that might be slipping as it may be worn , if so buy a new 1 they are not expensive . but a trict of the trade is to put a little more tension on the belt by moving the alternator slightly further away to add tension , if you do this and start engine and the lights dont dim you know its the belt if it does not improve and theres no screeching it could be the alternator.
Hope this helps
whiterabbit
No New Posts Lights
0 PAYNE 177 25th September 2008 - 06:14 AM
Last post by: PAYNE
No New Posts Lights On Electronic Climate Control
2004 Santa Fe 3.5
5 don1994 274 31st August 2008 - 09:14 PM
Last post by: Gacho
No New Posts Lights On The Door Panel Not Lit?
1 4Bigfoot 75 27th July 2008 - 12:58 PM
Last post by: DigitalAccent79
No New Posts And Another Thing ...
to like about Hyundai
9 Dennis the Mennis 290 1st July 2008 - 12:49 PM
Last post by: bobad
No New Posts Lights
Tail Lights / Brake Lights Won't Tur Off
2 FutureLawyer2010 197 1st July 2008 - 10:28 AM
Last post by: iceman77
23rd November 2008 - 11:53 AM
