QUOTE(Topini @ Jan 2 2008, 12:12 PM)
I'm sure that somebody has taken over 160hp from stock garret :)
[right][snapback]127249[/snapback][/right]
I don't believe you as the stock clutch can hold 170hp/225nm and the stock injectors is capaple of 170/225nm as this is dyno proven. I have no idea idea how much the fuel pump can take power as I had no probs. with 215bhp power and stock pump so that 180bhp fuel limit must be wrong.
Sure the stock clutch can handle more to make cool numbers for dyno paper, but it will be destroyed quite a soon. Everybody loves dyno braggers and dyno queen cars.
Or if you mean't 16
1 bhp, then of course :w00t: :thumbsup: :trophy:
Quite a pointless actually to think it.
Limp mode comes when you try to boost more than 1 bar with stock ECU. Chip it (Bosch motronic) or change it. Stock airflowmeter will limit your torque to 275nm, it's basic hotwire unit and the dump valve is not recommended with it, but bypass-valve is okay if you want some character for your scoupe.
This post has been edited by eyelid: Jan 4 2008, 10:10 AM
