 Hyundai-Forums.com > Hyundai Models > Amica & Atoz Forum
> What Is This Part In Hyundai's Engine?, This is Santro/Atos 1.0 EFI Engine
Junaid_Hassan
post Aug 3 2007, 04:50 AM
Drives: 2002 Hyundai Santro 999cc
Please any body tell the name and function of this part in Santro's engine. It is fitted above the throttle body.
It is creating a humming and hissing noise in my Santro and it becomes very hot, is it normal???
Attached File(s)
byronguidry3732
post Aug 3 2007, 10:33 AM
Group Icon
Group: Super Mod
Dear Junaid,
While we do not have the Santos/Atos in the U.S., the part in your picture is in the correct location and correct shape as the Throttle Position Sensor on the U.S. spec Elantra.
Because this part is connected to an aluminum throttle body that conducts heat upward from your engine, this WILL get hot. This is normal.
You also said that this part creates a 'Humming and hissing noise".
Can you determine if you have Multi-point fuel injectors? Characteristics to look for would be a an electrical wire leading to 4 different plastic bodied injectors mounted on a small diameter fuel gallery (rail) that resembles a pipe the diameter of your little finger (7/16 inch). If you do not have Multi Point Fuel Injection, you have an older system called Single Point Fuel Injection. A SPFI will have a single large fuel injector mounted in the throttle body. It is normal for an SPFI to hum, hiss, and get very hot as it has an injector valve opening up to 10 times per second. You can determine that you do have SPFI by looking for a fuel line leading to the SPFI. Also, if you disconnect the electrical connector shown the engine 'dies' immediately. Also, if you place a long blade screwdriver to touch the throttle body next to this fitting, place your ear on the OTHER END of the screwdriver, you will HEAR the injector spraying fuel into the throttle body.
byron
This post has been edited by byronguidry3732: Aug 3 2007, 10:34 AM
Attached File(s)
Attached File  2001_Elantra_Throttle_Position_Sensor_E3KC304F.jpg ( 99.32K ) Number of downloads: 298
NovaResource
post Aug 3 2007, 10:59 AM
Drives: Nautical Blue 2006 Tucson 2.7L V6
QUOTE(byronguidry3732 @ Aug 3 2007, 11:33 AM)
Dear Junaid,
While we do not have the Santos/Atos in the U.S., the part in your picture is in the correct location and correct shape as the Throttle Position Sensor on the U.S. spec Elantra.[right][snapback]100839[/snapback][/right]
I don't think it's the TPS because it's is on the top of the intake, not connected to the throttle blades. The TPS is usually directly opposite of the throttle arm. I believe the TPS is the sensor just below the one in question in the first picture:
http://www.hyundai-forums.com/index.php?ac...pe=post&id=4626
My guess is the item in question is actually the IAC (Idle Air Control) motor.
byronguidry3732
post Aug 3 2007, 11:08 AM
Group Icon
Group: Super Mod
Dear Nova,
[/quote]
[right][snapback]100842[/snapback][/right]
[/quote]
OK, here is the picture of the Idle Speed Control Actuator.
Should this hum and hiss in normal operation?
Byron
This post has been edited by byronguidry3732: Aug 3 2007, 11:09 AM
Attached File(s)
Attached File  2001_Elantra_Idle_Speed_Control_Actuator_E3KB304P.jpg ( 16.39K ) Number of downloads: 301
NovaResource
post Aug 3 2007, 11:22 AM
QUOTE(byronguidry3732 @ Aug 3 2007, 12:08 PM)
[right][snapback]100845[/snapback][/right]
Not if it's sealed properly. My guess is there might be an air leak where the IAC connects to the throttle body. Spray some carb cleaner or WD-40 around the base of the sensor where it attaches to the TB. If the idle speed changes, there is an air leak.
matttttttt
post Jul 11 2008, 10:12 PM
Drives: Accent 1.6
How can I clean this idle Speed Control Actuator? Can someone explain? The plug-in is not clip on, how can I unplug it? I wonder if there is some pictures ?Thanks!
No New Posts Instrument Panel Lights
3 rcacs 34 Yesterday, 12:33 PM
Last post by: rcacs
No New Posts Engine Shut Off
What's going on?
20 penguin_hash 663 Yesterday, 09:58 AM
Last post by: wagsmachine
No New Posts Parting Out 2006 Huyndai Azera "new & Used"
Engine Parts New in Box and used Azera
0 4jrfox 8 29th November 2008 - 10:39 PM
Last post by: 4jrfox
No New Posts Engine Wont Start When Hot
4 kev f 125 28th November 2008 - 12:56 AM
Last post by: Madogi
No New Posts Infinity Sound System Hiss
Has anyone found a solution yet?
17 torscotty 196 26th November 2008 - 04:39 PM
Last post by: Ken SantaFe
2nd December 2008 - 07:32 AM
