Byron (and/or anyone else who can help),
Having read this thread I regard this "timing belt" is a critical part in Hyundai engines.
Please treat the questions below as a question from a totally newbie.
Can you explain a bit about that "timing belt":
- Where is it (easily visible from outside or inside engine block that needs lots of work)?
- Is it physically a chain or a belt?
- Is it replaceable by ordinary car owner or a professional help is required? (I am familiar enough to motorcycle engine, including repairing many parts of motorcycle engine, but relatively new to car engine. I own Hyundai Atoz)
Thanks for the information.
QUOTE(byronguidry3732 @ Jul 30 2007, 10:17 PM)
:00000732: Junaid!
All Hyundai engines are 'interference' engines, meaning that if the timing belt breaks, serious engine damage will result from the pistons striking the valves. This can require a complete engine rebuild depending on the severity of the strike. Bent valves and a cracked engine cylinder head are common.
the timing belt should be changed at 96,000 Km or 60,000 miles.
Byron
[right][snapback]100098[/snapback][/right]
