:00000732: limch!
When you change the flow volume of the exhaust or block out the O2 sensors, you absolutely will have Check Engine Lights!
1. For a 4-2-1 headers see:
http://www.sharkracing.com/acecart/bin/sho...&cate=0104030002. what about the O2 sensor? Your headers absolutely need the O2 sensor bung holes in the correct places to provide proper digital signal input to your engine computer
3. what about catalytic converter? A properly designed header with with O2 holes in the correct places will still work correctly with your catalytic converter.
4. You changed to a 4+1 without cat converter. This was a bad choice, as you need the O2 sensors to provide the proper digital signal back to the engine computer.
5. Please install a proper header with the O2 bung holes to fix your problem. You may need your Elantra engine computer re-programmed to accomodate the higher exhaust velocity and volume.
byron
This post has been edited by byronguidry3732: Jul 30 2007, 04:34 PM
