QUOTE(bouleau2 @ Jan 9 2005, 08:35 AM)
Hi all,
I have a new 2004 Sonata with a 2.4 motor and when in gear and the brake depressed, I can feel a shake on the steering whell. The dealer told me it was normal, is it ? Anyone had that problem ?
[right][snapback]4634[/snapback][/right]
Hi there I have the same car and I find that mine does the same thing. I believe that it is normal as it is a large displacement 4cyl. motor and they have an inherant vibration. The reason this happens when it is in gear is that the engine speed drops when in gear and the large diplacement of the pistons make the engine cradle vibrate and you feel this through the steering etc.
On you other post why did they replace the alternator?
