Hi Randal,
As a potential buyer, I never see many trajets in the garage - I thought it was a reflexion on the cars....but I guess the cost of servicing must put users off too! I like the idea of the van like size and shape, though I am also considering a larger estate
I would be be dubious about the service history especially if there hasn't been a timing belt change. I would seriously consider changing the timing belt right away. Do you drive many miles each year?
You asked the question "Does anyone know where I can find technical/mechanical information on how this procedure is done for this model?" - forget about RTFM as it takes a bit of skill in changing timing belts especially if you are not mechanicaly minded.
Get someone who knows what they are doing to do this. If you/they are changing the timing belt change then it would be worth changing anything else that might need changed when the engine is stripped down at that time. I did the same with an old datsun a few years ago and saved money that way (as I was diong 36+K per year.)
Is it necessary to go to the Hyndai dealer? Surely at 90K there wont be any manufacturers warrenty left. You should go to a privately owned garage, (VAT registered) and get receipts for all the "genuine" hyundai parts used.
Typically you could expect to be charged from £17.50 per hour for a private mechanic up to £50-ish per hour for a dealer. With 90K on the clock I know what I would go for.
Regards Chips
