2 Pages V   1 2 >
> Replace High Mounted Rear Stop Light?
cowboy
post Jul 9 2007, 11:05 AM
Drives: 2006 Hyundai Sonata GLS3.3
Howdy!
My high mounted rear stop light and driver side real stop/tail light seems to be burned out. After checking manual, I found nothing mentioned about replacing 'high mounted rear stop light' at all. It's weird enoguh. From hmaservice.com, I found how to replace bulb, but, still could not find how to open that light box or package. And refereing to 2005 model of Sonata, it says there are two nuts to be unscrew to open light box. However, I'm trying to find those nuts in my 06 Sonata.
wymi
post Jul 9 2007, 11:43 AM
Drives: Mine: 2007 Sonata Limited Platinum Edition Her's: 2007 Sonata GLS I4
From what I remember reading somewhere on this board, you have to unscrew the stoplight housing from in the trunk. The screws are kind of hidden and are hard to get to.
cclngthr
post Jul 9 2007, 11:49 AM
Drives: 2007 Hyundai Elantra SE
The high mount stop light is a LED array. It is mounted to the rear deck panel. Remove that and you have access to the screws that hold it to the panel.
The rear tail light bulb replacement requires you to remove the lens from the car to get access to the sockets.
madderhatter
post Jul 9 2007, 12:20 PM
Hyundai-Forums
Group Icon
Group: Administrator
Drives: 2006 Sonata LX (Gracie), 2002 C240 (Gretta)
QUOTE(cclngthr @ Jul 9 2007, 12:49 PM)
[right][snapback]96487[/snapback][/right]
In the NF Sonata it's not an LED array, it uses filament bulbs. I think it's the same bulb as the back-up lights. It says for sure in the manual.
byronguidry3732
post Jul 9 2007, 04:57 PM
Group Icon
Group: Super Mod
Dear cowboy,
Can't find your nuts! Whoa, time to get off that horse. Seriously though:
Owner's manual is useless.
Checked the latest Chilton's manual for the Sonata, and also no help
You are right....hmaservice.com is no help on the physical removal of the third brake light fixture.
It says:
HIGH MOUNTED STOP LAMP
Disconnect the negative(-) battery terminal.
Open the trunk lid and then disconnect the connector of high mounted stop lamp.
Remove the package tray (Refer to the Body group-package tray).
Replace the bulb(A) from the package tray.
Unfortunately, no pictures of someone actually removing the 'package tray'.
Guess you have to hunt for those nuts.
Byron
dogstar
post Jul 9 2007, 07:09 PM
Audio geek
Group Icon
Group: Super Mod
Status: Online
Drives: 2006 Sonata GL V6
Package tray is the panel behind the seats.... Its not incredibly hard to remove, but its a complete pain in the butt.
I believe Dennis the menace is writing up a how-to, but Im not sure if he is done.
Hopefully he will chime in with details.
Dennis the Menni...
post Jul 10 2007, 08:16 AM
Expert
Drives: "KC" 06 GLS 3.3L DOB 2-16-06 Bright Silver Metallic
The service manual often gives advice that's slanted toward the guys that maintain Hyundais for a living, day in and day out; once you've removed one <fill in the blank> the next one's quicker. Their advice is also slanted toward getting the job done in the least time. That don't help you to get your bulb (it IS abulb, not an LED) replaced, though.
Someone said there's a piece of foam tape covering an opening; if you remove it you can get to the bulb. I'll crawl in the trunk and take some pics this morning.
BTW, you DO NOT have to remove the tail lamp assembly to replace most of the bulbs; I think the innermost bulbs are the only ones requiring the assembly to be removed. Most are covered by a typical square panel you unhitch by unscrewing a plastic knob.
This post has been edited by Dennis the Mennis: Jul 10 2007, 08:19 AM
cowboy
post Jul 10 2007, 09:41 AM
I wrestled with it(if you ever did this job, then you might know what I mean by wrestle) more than one hour to take the bulb out, but, then gave up. I unscrewed two nuts, but, still it seems to be stuck and I couldn't take that out.
I did same job for my previous Camry 07. It was easy job, just replacing bulb. I do not understand, why Sonata makes this so difficult and why we even need to unscrew two hidden nuts to just replace high-mounted stop light.
I dropped my car at Hyundai dealer this morning for this stop light and some noise from steering wheel, which when I turn steering wheel, it makes some noise. It need to be rubbed or greased a little bit.
Dennis the Menni...
post Jul 10 2007, 09:50 AM
Expert
I think you have to remove the parcel tray.
The picture below
was taken from inside the trunk, looking up. You can see a square and a round hole. The round hole had foam tape on the other side, which I removed, but you can't get at the bulb from there.
I have small to medium hands, and the square hole isn't big enough to get at the bulb. I can feel something in there that I think is a plug, but I can only touch it.
I don't remember if the high-mounted stop housing has a "floor" or whether it's open at the bottom. If it's open a woman MIGHT be able to get their hand in there to pull the bulb but once pulled I don't know if it could be rassled out and replaced. The wife's hands are the same size as mine, and neither of us could feel anything but the "wire thing;" nothing like the 921 bulb below.
Obviously, not a very good design. The DIY that Dogstar refers to is coming along; I need to take 1 or 2 more pictures and I'll have Madder hose it. I mean, host it. :grin: Sometimes typos are best left in. :beer:
Attached File(s)
cowboy
post Jul 11 2007, 10:55 PM
Today I got my car back from Hyundai dealer. They replaced high mounted stop light and one of tail stop light(actually, I replaced it before dropping my car to dealer. I don't know what happen, why they did it again).
And it is covered by warranty and I paid nothing. But, they broke a black plastic part which is holding white plug for stop light. Originally, the black plastic part was sticking to something with nut.
I guess they tried to unscrew it and screwed up and broke it. I found it after I got home and didn't want to go dealer again just to argue about it. Actually, it seems that part is not doing much.
And for noise from steering wheel, they said they replaced some spring. After driving for few minutes, I heard noise is still there and went back to ask. Oh my got, what they said is each plastic part are expanded because of hot weather and when each plastic part move around, it make noise. it's not mechanical problem.
I asked disassemble and rub and assemble again. They said because it's not a mechanical problem, that is not covered by warranty and I need to pay. However, I doubt even if they do it, it will be really fixed? my answer is 'no'
That noise is not too noisy, but, it's annoying enough. I don't know what to do.
By today's experience, I would not recommend Hyundai to my friends.
Freval
post Jul 11 2007, 11:11 PM
Post #11
Drives: 2001 Santa Fe LX
:innocent: You say, you would not recommend Hyundai to your friends because of a Third brake problem. Wow what about the rest of the car, is it OK. Sounds like a dealership problem.
Sequoiasoon
post Jul 12 2007, 12:34 AM
Post #12
Drives: 2007 Sonata GLS 2.4L 5 Speed Manual
QUOTE(Dennis the Mennis @ Jul 10 2007, 10:50 AM)
The picture below
[right][snapback]96657[/snapback][/right]
Did you take the subwoofer out or not finish install yet or other? I see the hole and the grill covering but where is the sub???
Dennis the Menni...
post Jul 12 2007, 12:55 AM
Post #13
Expert
The hole and grille are to let the bass notes into the cabin. The sub is an Infinity Bass Link that lives on the floor of the trunk with the door speakers' amp.
joekewl
post Jul 12 2007, 04:52 AM
Post #14
Car Crazy Expert
Drives: 2006 hyundai sonata lx
QUOTE(cowboy @ Jul 11 2007, 10:55 PM)
[right][snapback]97058[/snapback][/right]
lol for that?
i had an 89 grand prix se when the sun hit the windshield at the right spot i couldnt see out it some kind of defect i was told what ? do you think im going to replace that? not going to happen, well needless to say somehow a rock somehow flew up
and hit my windshield a week later. good thing i had glass insurance :whistling:
cowboy
post Jul 12 2007, 09:20 AM
Post #15
Well, if I make myself clear again;
-My car has noise from front right area around tire.
-My car has noise from steering wheel. It's very annoying.
-Broke part and never mentioned to driver...(really, funny)
However, Hyundai dealership said,'Your are is in perfect condition' and some of silly explanation which does not make sense at all. It's very frustrating.
Whatever happened, they just say 'Your are is in perfect condition'
I know this is not a Hyundai problem, it is a specific dealer problem, however, the quality management of dealer is still Hyundai's responsibility. Hyundai should check the quality of dealer and kick them out if not qualified for better customer's satisfaction and for the reputation of Hyundai.
Has anyone experienced acceptable Hyundai service, by the way? I am really curious.
dogstar
post Jul 12 2007, 07:00 PM
Post #16
Audio geek
Group Icon
Group: Super Mod
Status: Online
Ive gotten great service on mechanical items, but the back-up on the cosmetic issues has been terrible.
CptGloval
post Jul 13 2007, 02:44 AM
Post #17
Drives: 2006 Hyundai Sonata 3.3L 6cyl.
don't go through the hassel.....covered under warrenty!
sonata with seou...
post Jul 13 2007, 03:31 PM
Post #18
