Ok.... the A/C in my excell stopped working. When you press the little button on the center dashboard the green light does not come on and nothing happens. I have checked the Relays & fuses and they are ok. If you manually engage the relay (bridge the contacts ) in the fuse box under the bonnet it works, so I know the motor & pump is OK. Also this should mean that the relay is OK too I think,would that be correct?? Could it just be a blown bulb in the dash switch?? which is breaking the circut??
:thumbsup:
