 Hyundai-Forums.com > Hyundai Models > Tucson Forum
> 2005 Tucson Gl - Hard Start, Occassionally hard to start.
dlove_rm
post Jun 25 2007, 03:56 PM
Drives: 2005 Hyundai Tucson GL 2.7
Occassionally, the Tucson is hard to start. Especially noticable after it has been driven - then parked for a period of about 2 hours. When we attempt to start it again, it cranks, it attempts to start but just does not. It takes several attempts, then if we let it sit for about 20-30 seconds and try again - it will fire right up.
Any thoughts?
Its a 2.7L V6 Gasoline - Automatic - and it has been alot more noticable since the summer has hit and we are running the A/C.
Thank you,
Jenna2002
post Jun 1 2009, 04:43 PM
Drives: Hyundai Tucson 2005
Did you Ever figure out the problem? I have had the EXACT same issues since around the same time. I finally took it to another mechanic because hyundai kept charging money for something they couldnt fix.
QUOTE (dlove_rm @ Jun 25 2007, 01:56 PM) *
Any thoughts?
Thank you,
itza
post Jun 2 2009, 03:58 AM
Expert
QUOTE (Jenna2002 @ Jun 1 2009, 10:43 PM) *
First off try changing the spark plugs as often this causes some of the problem and is not to expensive to do and will benefit anyway if this is not the problem. Then if you still have warranty get the dealer to checkout the TPS (Throttle position sensor) as this too can cause that type of symptom without showing up on the cars computer system.
Hope it helps
Itza
watercat01
post Jun 18 2009, 04:14 PM
Drives: 2005 Tucson LX 2.7
Two weeks ago I started having the exact same problem with my 2.7L V6. It turns out the FUEL PUMP was not holding pressure after the car had sat for a while. Have someone run a fuel pump pressure test to confirm. I just had the FUEL PUMP replaced (warranty) and now it fires up on the first try like it should. Hope this helps.
watercat01
No New Posts Starting Trouble
1 dyxlexic 37 5th November 2009 - 09:15 AM
Last post by: rie64
No New Posts Topic has attachmentsGls Vs Limited Vs Se
4 moonlight 153 1st November 2009 - 06:58 PM
Last post by: Jake Jacobson
No New Posts 2005 Accent Idles Rough
3 Stooge 57 31st October 2009 - 06:55 PM
Last post by: rsquared
No New Posts 2005 Senata Cut Off Wont Start Even After All New Parts Installed
ecu,cps,fuel pump??
0 mason704 33 26th October 2009 - 05:53 PM
Last post by: mason704
No New Posts Topic has attachments2005 Tuscon Temperature Control Knobs
1 Bigdawg007 92 22nd October 2009 - 06:22 AM
Last post by: itza
7th November 2009 - 02:47 PM
Privacy Statement
