 Hyundai-Forums.com > Hyundai Models > Tiburon Forum > RD Tiburon (1996-2001)
> 2000 Tibby Problems, stalls and shorts.
gearhead420
post Jun 22 2007, 12:36 PM
Drives: 2000 Hyundai Tiburon
Hey guys, I recently bought a 2000 tib and it has started to stall or just sputter when I try to start it. I replaced the fuel pump and relay and put a new fuel filter in it. Anyone have a suggestion? Also there is a short some when causing the door alarm to ding every once in a while when rolling the drivers side window up or down. any help would be great thanks.
byronguidry3732
post Jun 22 2007, 03:31 PM
Group Icon
Group: Super Mod
Dear Gear,
Use this diagnostic. Sign up at www.hmaservice.com
Byron
Attached File(s)
nihar15
post Aug 13 2007, 10:59 AM
Your door alarm ding could be a bad door switch. Its the black switch on the door wall with a large phillips screw underneath it. You can replace the switch or just remove it as I did ;-) Open the screw, the black switch will dangle out. It is a push connected to a white connector. Pull it out and put the switch back in.
Carloboy
post Aug 19 2007, 05:19 PM
Drives: 2000 Hyundai Tiburon, 2.0 liter, manual transmission
Try changing the sparkplugs. If you just bought it used, you dont know when they were last changed if changed at all. When I put in new spark plugs in my 2000, it took care of the sputtering/stalling I was having.
tibbydude
post Aug 19 2007, 05:25 PM
Drives: 2007 tiburon gt 2.7
yes spark plugs would probably go bad and cause the sputtering because hyundais use hemisperical heads which abuse the spark plugs badly because incomming air/fuel and exiting hot exhaust is rushing past it so closly so check then out if its not that it could be an o2 sensor
No New Posts 2000 Lantra Electrical..
4 cokaznrebel 30 30th November 2008 - 03:03 AM
Last post by: cokaznrebel
No New Posts 2000 Tiburon Trouble Code
1 Tiburonjoe 9 19th November 2008 - 11:16 PM
Last post by: byronguidry3732
No New Posts 2000 Sonata V6 Rear Brake Problem
2 surfboarder 22 17th November 2008 - 05:23 PM
No New Posts 2000 Elantra Parts
8 mikeoxbigg 436 12th November 2008 - 04:09 PM
Last post by: mikeoxbigg
No New Posts 2000 Elantra Tire Size Change
0 yagru 9 5th November 2008 - 11:25 AM
Last post by: yagru
2nd December 2008 - 05:35 PM
