QUOTE(Explorer 1 @ Nov 2 2007, 11:28 PM)
I have the same problem B4. Got it done for RM150.00. I believe it is the second Oxi sensor. Just get a secondhand sensor with 4 wires will do. Many other made of car have it. Only cost about RM90.00. Labour is abit expensive as it is very difficult to replace. After replacing it just do a reset.
[right][snapback]116925[/snapback][/right]
Do you know the OEM model for the 1st O2 sensor? The one just after the exhaust manifold/header and before the 1st CAT.
My current ride is 04' Trajet CVVT 2L engine (G4GC) and mileague is almost 120k km. The CEL comes one with a P0133 code which means "O2 Sensor Circuit Slow Response" (see attach) and I have use Scan Tool to clear it but it will come back again (about once every 3 to 6 weeks of driving).
Taken from
http://www.obd-codes.com/trouble_codes/gen...-1-sensor-1.php A code P0133 may mean that one or more of the following has happened:
- The oxygen sensor is faulty
- The wiring to the sensor is broken / frayed
- There is an exhaust leak
I have found out that the stock cast iron header is crack at 2 location, at 2 & 3. Last week I've replace it by a stainless steel 4-1 header and now the CEL with P0133 comes back again.
So, exhaust leak is out and the only possible cause will be the faulty O2 sensor.
Buying a used car can really have lots of problem :crying:
This post has been edited by Vtim: Nov 4 2007, 11:54 PM
