The story starts when i get home from basic training. My car wouldn't start but cracked. I completely changed the electrical system including coil and all. Nothing. Then i learned that my ECU was fried. I visited a junkyard and got another ECU only probably was my stock ECU was a Z29 and they gave me a Z31. It worked for awhile, then I started to get a lack of power in the engine. I can diagnose it as idles alittle rough, and when i hit the accelerator, when it cold, it bogs down. It seldomly stalls when i put it in gear, especially when its cold. As of recent, my check engine light came on, it told me to check EGR, i took my EGR case off. It was completely stopped up with carbon, I cleaned it hoping it was my cure; but the same old lack of power. I changed the EGR temperture sensor because it didn't give me an OHM reading. And the new one doesn't give a reading as well.
Now, I'm stuck with a car that doesn't work properly, i can drive it still but its no fun; cause I know how the car used to drive. Please Hyundai gods, help me!
