Lean Exhaust Codes, Check Engine Light - Bank 1 & Bank 2 Ox.
| bradrel |
Jun 8 2007, 10:38 PM
Drives: 2001 Hyundai XG300L Status: OFFLINE
Hello everyone,
I recently picked up a 2001 XG300L. It's my first Hyundai and I love it. Unfortunately I ran into my first problem.
The check engine light came on. I checked the codes and they came up as: P0171 and P0174, which I understand is lean exhaust codes on oxygen sensors, bank 1 and bank 2. I replaced the fuel filter, but that didn't take care of the problem. I also cleaned the Mass Air Flow Sensor. I also checked for vacum leaks but found nothing. (The car is running fine)
Here's the question: What's next?
Should I go ahead and start replacing the oxygen sensors or try something else?
Thanks in advance.
Brad
EDIT: It has about 87,000 miles.
UPDATE: Replacing the Mass Air Flow seems to have fixed the problem. No check engine light and no stalling in about 2.5 weeks. Thanks to -byronguidry3732- for the solution. :clap:
This post has been edited by bradrel: Sep 28 2007, 08:08 PM
| bradrel |
Jun 9 2007, 07:40 AM
QUOTE(montego @ Jun 9 2007, 06:05 AM) welcome to the forums :00000732: you say that the car is running perfectly fine. if thats the case l would disconnect the battery ground lead for a few mins. to turn the light off and re-set the computer, run the car again and see what happens, if the light comes on again with the same fault code it looks like you may have to change the sensors Thanks for the reply! Unfortuantely I have reset the codes several times, each time they have came back on within about 20 miles. Brad This post has been edited by bradrel: Jun 9 2007, 07:41 AM
| mayer486 |
Jun 10 2007, 01:17 PM
Drives: 2001 Hyundai XG300 Status: OFFLINE
I have the same problem and its probably the MAF sensor. I cleaned the heck out of it one time, reset the codes, and the check engine light didnt come on for about 120 miles and when it did i didnt notice any difference. I just clean it periodically and dont have any issues including fuel economy. It's just one of those things Hyundai didn't resolve. but hey, if u come across any developements let me know. i wouldnt worry about it unless u come across noticable problems.
| fegbri |
Jun 12 2007, 02:21 PM
Drives: XG300L Status: OFFLINE
Crazy, I am experiencing the same thing now. But my car will shutter at start up sometimes, or randomly. I need to take it in...
| byronguidry3732 |
Jun 12 2007, 03:23 PM
Group: Super Mod
Drives: 2003 Tiburon GT 2.7, 2004 Santa FE FWD 2.7, 2001 Sonata 2.4, 2000 Elantra, 1984 Pontiac Fiero SE Status: OFFLINE
Dear bradel, :00000732: first. Did you know that you have a specific Tech Service Bulletin for P0171 and P0174 on your car? [Pause for slow bow to roaring applause] Byron :whistling: Attached File(s)
XG300_Code_P0171__P0174_04_36_020.pdf ( 21.56k )
| bradrel |
Jun 14 2007, 02:00 PM
QUOTE(byronguidry3732 @ Jun 12 2007, 04:23 PM) Dear bradel, :00000732: first. Did you know that you have a specific Tech Service Bulletin for P0171 and P0174 on your car? [Pause for slow bow to roaring applause] Byron :whistling: :clap: (Roaring Applause) :clap: Thanks! I will be checking this in the next week or two. Brad
| byronguidry3732 |
Jun 21 2007, 12:42 PM
Group: Super Mod
Dear angieb,
NEVER assume that the service tech is smarter on your car than you are. NEVER.
Real life: I actually had to print out the alignment specs for my Santa Fe when they set it wrong and fold their little tiny fingers around the piece of paper for them to get it right.
Also, I caught them using an impact tool on the rear camber adjustment nut. So I printed off the TSB warning not to use impact tools on camber adjustment nuts or damage will result...etc.
Always be prepared to hand them the TSB. Shame on them but such is the service departments at most dealers these days.
Also, don't assume the salesperson knows more about the car he/she is trying to sell you than you do. They don't.
Byron
| astampfel |
Nov 8 2007, 12:23 PM
Drives: 2001 XG300L 3.0L Status: OFFLINE
I have the same problem, the lean codes on the left and right banks. I changed a fuel regulating valve, but that only worked for a week. The codes go out periodically, but the always come back. My car shutters sometimes also, so I took it in to get the codes read and they said I had a misfire in cylinder #6. So, I'm going to change the spark plug in that cylinder. The problem is that I don't know what cylinder is #6.
I don't think both of my O2 sensors failed at the same time, so I don't think that is the problem. I guess I'll look into the MAF next.
| astampfel |
Nov 22 2007, 12:08 AM
I have the exact same problem. I got the check engine light last year, and it said that I had lean fuel on left and right bank O2 sensors. I didn't think both of my sensors failed at the same time, so I thought the engine wasn't getting enough fuel. I took off the engine cover and physically agitated (hammered) the fuel reg valve. This helped for a little while, but the light came back. The light was intermittant for the next year. Then, my car started to shutter sometimes. So, I got the code read again,and they said I had a misfire in cylinder #6. I didn't know which cylinder 6 was, but I knew it was in the front of the car, so I changed the plugs in 2,4,6 to be safe. I would have changed 1,3,5 but they are under some type of manifold/cowling. My car runs better now, but I still have the check engine light. After reading this forum, I bought a MAF online on ebay. It was about $80 cheaper than the dealer. I'm going to change it tomorrow and I'll let you know what happens.
Track this topic
Subscribe to this forum
Download / Print this Topic
Link To Us
Similar Threads
Similar Threads
8th September 2008 - 03:02 AM |
