QUOTE(purple_nat @ May 28 2007, 06:09 AM)
Hi,
I've recently bought a 2.7 V6 Auto Trajet (2001), it's been going very well until recently.
The issue I'm having is inconsistant and does not happen at a specific speed or RPM. The CEL will illuminate and the car will jolt, as if being knocked out of gear, however the gears are still engaged but the acceleration is poor and it seems not to be above third gear. It changes done with no problem.
I noted down some performance figures before and after the CEL came on...
before ...at 60mph the RPM is 2400
after ...at 55mph the RPM is 3000 + poor excelleration
Has anyone experienced this problem and could provide some advice.
Thanks in advance.
purple_nat
[right][snapback]89866[/snapback][/right]
If the CEL is up, it mean some sensor is down. Looking your problem, think its time to change the gearbox sensor...bring to a service centre to scan for the exact fault code, it will tells you the fault. :)
