Turtle Wax Ice Polish |
May 26 2007, 05:17 PM
Status:
Drives: Sonata EF+NF V6 GLS
QUOTE(motd @ May 26 2007, 11:31 PM) Thanks for the heads up. I'll stick with the NXT from Meguires. [right][snapback]89769[/snapback][/right]
Nxt. Generation Tech Wax Paste - rocks - The best i have tried so far...
May 26 2007, 09:02 PM
Expert
Status:
Drives: 2006 Sonata GLS Sport
QUOTE(Carlos Sonata @ May 26 2007, 08:33 PM) If you've used touch-up paint on dings and scratches (Hyundai paint pen or other), is it okay to wax/polish the touched up area? With the paint being so thin, will it take it right off? [right][snapback]89793[/snapback][/right]
Carlos, I have over a dozen spots throughout the car that I've touched up and each one gets waxed just like the rest of the car. I haven't seen any come off. Don't worry about it. Wax on, wax off! -N- :thumbsup:
May 26 2007, 10:28 PM
Status:
Drives: 2007 Hyundai Sonata GLS V6
I used Ice Liquid Polish on my black Sonata with excellant results. I am very happy with the product.
May 27 2007, 03:59 AM
Status:
Drives: 2006 Sonata
QUOTE(normandelli @ May 26 2007, 09:02 PM) Carlos,
-N- :thumbsup: [right][snapback]89796[/snapback][/right]
Thanks Norman. :57:
Jun 3 2007, 12:27 PM
Expert
Status:
Drives: 2006 Hyundai Sonata LX
QUOTE(joekewl @ May 30 2007, 11:50 AM) maybe the ones who had problems werent using a microfiber towl to buff [right][snapback]90230[/snapback][/right]
Not true. The turtle ICE WAX (discussed in TURTLE ICE WAX BETTER THAN SLICED BREAD?) is actually very easy to apply almost a joke although i cant say I like the little pad they give you. seems too abrasive. you could do the whole car and wait for 20 min and it is very difficult to BUFF much worse than traditional wax REGARDLESS OF WHAT KIND OF TOWEL YOU USE. ALthough I have noticed using a clean towel for each panel of the car makes the job A LOT EASIER since you dont have excess run off keep rubbing onto the car causing streaks But some people are just too cheap to get a few extra shop rags Also after buffing doing panel by panel with the spray detailer helps with the streaks. but you have to buff it WHILE WET or else its very difficult. Also use clean rags as often as possible to prevent excess run off streaking OVERALL SHINE IS GOOD. WAS HOPING FOR A LITTLE LESS EFFORT BUT I can live with it. i
Jun 3 2007, 03:24 PM
Car Crazy Expert
Status:
Drives: 2006 hyundai sonata lx
QUOTE(ohsnapitswillayy @ Jun 3 2007, 12:27 PM) Not true. The turtle ICE WAX (discussed in TURTLE ICE WAX BETTER THAN SLICED BREAD?) is actually very easy to apply almost a joke although i cant say I like the little pad they give you. seems too abrasive. you could do the whole car and wait for 20 min and it is very difficult to BUFF much worse than traditional wax REGARDLESS OF WHAT KIND OF TOWEL YOU USE. ALthough I have noticed using a clean towel for each panel of the car makes the job A LOT EASIER since you dont have excess run off keep rubbing onto the car causing streaks But some people are just too cheap to get a few extra shop rags Also after buffing doing panel by panel with the spray detailer helps with the streaks. but you have to buff it WHILE WET or else its very difficult. Also use clean rags as often as possible to prevent excess run off streaking OVERALL SHINE IS GOOD. WAS HOPING FOR A LITTLE LESS EFFORT BUT I can live with it. i [right][snapback]90841[/snapback][/right]
um whats not true ????????? if you read above people where complaining about it maybe they should try a microfiber towel that is what im saying so i dont know how it can be true or not true i wouldnt be caught dead waxing my car with a shop rag would do wonders for the clear coat
Jun 4 2007, 09:48 AM
Expert
Status:
QUOTE(Carlos Sonata @ Jun 4 2007, 06:15 AM) I picked up an Original California Car Duster thing from Costco the other day and wondered if anyone here uses one (or something similar) on their Sonata between washings. The package says it has "exclusive baked-on wax-treated strands" and "special Non-Volatile, odorless & colorless, Paraffine oil." Could this damage the Sonata's paint? [right][snapback]90956[/snapback][/right] Carlos, I've been using that duster for a long time now - I love it. What's weird about it is the dirtier it gets, the better it seems to work. I've only occasionally smacked it against something to dislodge loose dirt/dust but I've never washed it yet. Perfectly fine for your car's finish - enjoy using it! -N- :thumbsup:
