Which side of the car is the battery on? What side and where are you mounting the amp? The easiest place to go through the firewall is at the steering column. If you look under the hood you will also be able to see plugs in the firewall where there is a hole but nothing routed through it. You can drill a small hole in the plug and run your cable through there and put some silicone sealant on the cable to reseal that spot in the firewall. Short of drilling your own hole those are the 2 easiest ways through the firewall.
Hope this helps.
