> Accent Dashboard, How do you remove the Accent car radio?
shabbir2q
post Dec 31 2004, 07:01 AM
Drives: hyundai accent
Hi, can anyone tell me how to remove the Accent dash board so I can remove the factory Audio unit with a new one? I can only see two screws behind the ashtray, but this does not allow the unit to come out....
HELP ! ! :( ! ! :(
VALKYRIE YB70
post Dec 31 2004, 07:36 AM
Mod Emeritus
Drives: Modified (180 b.h.p.) `95 Hyundai S-Coupe Turbo SE ....Sadly now sold & replaced with an `04 Alfa Romeo 156 2-litre Veloce! :-http://aol.photobox.co.uk/album/thumbnails.html?c_album=7089276&page=all
Hi there!.
Everything you need to know about removing the audio & console is here :-
http://www.hmaservice.com/webtech/iindex.a...7972#_394877972
I hope this helps you out!
Nick. :)
soullink
post Jan 3 2005, 04:05 AM
Group Icon
Group: Moderator
Drives: Hyundai Accent MVI - 1999, 1.5i, 16 valve - www.soulaccent.com
I'm not sure about the newer accents, but I have the old accent (1999 reg) and all you do is remove the two screws behind the ashtray (which you have already found) and then pull off the facia (a bit difficult) - the rest is held in with metal clips (which I found pinged off behind the center console :angry: ).
It will be quite hard to pull the facia out as it has all the buttons and dials attached to it - so unpluggin a few might make things a bit easier, but the heater controls are attached by cables and will try and pull the facia back in. I managed to change my head unit without removing these, so it is possible.
Let us know how it goes.
sdanny21
post Jan 3 2005, 07:48 PM
Drives: Hyundai Accent 1999, SOHC 1500cc
Usually I also remove 2 screws at right side and behind center panel. These screws connect thermocontrol/heater control lever from center panel to blower box.
Then you will have more space to replace your audio system. :)
AnthonyKelly
post Jan 4 2005, 11:00 AM
Drives: Hyundai Accent 1.3
Hi. Amazing co-incidence but I've just this minuted joined the forum. Anyway, to remove the audio unit you have to remove the cables going to the air outlet units. If you open the glove compartment fully you will see a cable with a loot at the end, unclip this. (You'll probably need to remove the cable from its clip-on brackets to give a bit of slack). On the other side of the audio unit you will find two more similat cables, unclip these as well. Open the drinks tray and you'll see two retaining screws, if you take these out you can remove the central unit. I've recently done this on a 2001 Accent (right hand drive). Regards Anthony.
QUOTE(shabbir2q @ Dec 31 2004, 01:01 PM)
HELP ! ! :(  ! ! :(
[right][snapback]4237[/snapback][/right]
31 PastorK 874 Yesterday, 08:45 PM
Last post by: PastorK
No New Posts Topic has attachmentsAccent Vs. Deer
The deer was at a handicap...
9 blazianenigma 135 29th November 2008 - 12:58 AM
Last post by: hyunnychub
No New Posts Dashboard Confession
09 Limited Noise
18 carter39041 432 26th November 2008 - 09:51 PM
Last post by: madderhatter
8 cantfoolthewise 140 17th November 2008 - 11:11 AM
Last post by: cantfoolthewise
No New Posts Dashboard With Clock And Instrument Cluster
0 semitek 139 12th November 2008 - 03:52 PM
Last post by: semitek
2nd December 2008 - 07:11 PM
