QUOTE(1sonataowner @ Dec 27 2004, 08:51 PM)
My Sonata used to start fine. Had not started it in a while, then when I went to start it , the engine cranks but that's it. I changed the module behind the coil pack, and it started. I started it 4 other times and then it stopped. there is no spark in the spark plug wires. I also changed the noise (reducer)
4cylinder , 16 valve
Apppreciate your help (in advance)
[right][snapback]4097[/snapback][/right]
at the end (#4) of the head is the crank angle sensor; follow the harness till you get to the connector; undo the connector and check if all the terminals are ok and clean; reconnect and try starting
