:) Hi,
Perhaps the first thing to do is a service.
Replace the plugs, leads, fluids and filters.
Check the brake pads and linings and brake fluid also and replace if necessary(brake fluid does go off). You wanna stop if you're gonna go faster!
Make sure your suspension is up to scratch. Get Pedders to check it. The Granville store did an excellent job on my Lantra.
Use 98RON fuel like BP Ultimate or Vortex 98. Do this AFTER you have replaced your HT leads or the increased voltage from the computer may just fry them if you have been running on standard unleaded.
Ensure all your belts including the timing belt have been checked and replaced where and when necessary.
You'll be surprised at how much difference doing these things will make to the vehicles performance.
Apart from that, do your intake first(with cold air feed), then your exhaust or maybe consider a performance chip like a Powerchip or Unichip. Allow yourself around $700-$1000 for these basic mods.
Hope this helps,
Andrew. B)
