QUOTE(96sonata @ Dec 24 2004, 05:21 AM)
This morning i tried to start my car only to find that the key wont turn 1 bit, its stuck on lock. Last night it was running fine, there has been no previous problems indicating that this would happen, it was out of the blue. The key goes in and out fine, just doesnt turn.
Ive tried everything from jerking the steering wheel, tripping the shift lock, checked all the fuses and they all seem to be fine. I thought that something may have broken inside the lock barrel so i called an auto locksmith and he quoted about $160 just to come out and have a look at it :o
Maybe this has happened to someone else before? Any help would be rgeatly appreciated, dont really wanna spend $160 +
The car is a 96 Sonata.
Thx.
[right][snapback]4024[/snapback][/right]
this is quite normal for all cars, when the steering wheel is hard against the locking pin of the ignition switch. Try to turn the steering wheel side to side while turning the key
