QUOTE(dd716ted @ Dec 22 2004, 03:17 PM)
I thought I would ask before I started taking measurements at the panel.. Does anyone know if some of the fuses at the inside fuse panel are constantly hot while others are switched... such as the radio should be switched (on/off with the key) while others should be hot all of the time (interior lights). Would appreciate anyone's inputs.. Thank you
[right][snapback]3948[/snapback][/right]
some are "hot", some are not. the radio, ECM, TCM & others have a hot wire to retain the memory, and a 2nd one when the ignition is on.
