> Oxygen Sensors
MyKidsSonata
post Apr 9 2007, 08:05 AM
Drives: 2000 Hyundai Sonata GLS V6
I recently bought a 2000 Sonata V6 GLS. Only 51,000 miles but it may not have been cared for properly. I just had a speed sensor replaced, now 30 miles later the CEL is on again.
So I took it to Autozone: p1134 and p0153; did a quick search on this site and see that now I should get my oxygen sensors replaced.
any idea how much this repair is going to set me back? Should we still drive the care until we get it fixed or just let it sit to avoid additional issues?
Also, any idea why these codes didn't show up earlier when the car was with the dealer? Is there a limit to how many codes show up at a time? This is a pain to take the car back in and I can't get an appointment for about a week
thanks
Gary
Hyundai101
post Apr 9 2007, 10:21 PM
Drives: 2006 Santa Fe 4WD, 05 Honda Accord 4 Door.
The P1134 code doesnt seem to work for Hyundai.
The P0153 is O2 Sensor CKT Slow Response (Bank 2 Sensor 1).
I'm not 100 percent sure, but I dont think is a limit on how many codes can be displayed. I've had up to 5 on the scanner.
ssonata78
post Apr 14 2007, 01:05 AM
Drives: 2000 Hyundai Sonata GLS V-6
02 sensors are about 100 dollars for parts and easy to replace-disconnect the electrical connector and then loosen the senser with a socket specially made for that in which you can get at any auto parts store. My speed sensor went out as well but they were covered under warranty as well as the 02 sensors but yours is getting to that age where its prolly not covered but its worth the call. I thought they had issues with the sensors and if they were bad they would replace them if not they wouldnt. You need to find out which 02 sensor it is to get the correct one on order and I went to the dealer for mine and they asked for my vin to get a match for the sensor when it went out again. I wouldnt drive too long on it for one you can waste gas for 2 i heard it can make other things go bad if left too long but ive seen people drive years with it on and they know its the 02 sensor. Sometimes i disconnect my battery to clear my codes and they dont come back right away everytime. I have had a few codes at the same time so i think that depends on the reader that was used, just ask Autozone how many it can read.
Steve
This post has been edited by ssonata78: Apr 14 2007, 01:11 AM
duke
post Apr 14 2007, 06:45 AM
Community Advisor
Group: Community Advisor
Drives: 2007 NF Sonata 2.4L
There is a TSB for the 2000 Sonata, were the O2 sensor has to be replaced with a newer type, and the ECM must be reprogrammed.
LowSonoma1999
post Apr 14 2007, 09:09 AM
Drives: '93 GMC Typhoon
If you decide to replace the oxygen sensors, and you are replacing one or both of the upper ones, go to the dealer, they are cheaper there. The upper oxygen sensors list at $39.03/ea. Much cheaper than anything you can buy from the aftermarket. Dealers are allowed to charge whatever they want, and 98% of them charge more than list price, so expect to pay more than that. I can do $29 plus shipping on them if you want.
ssonata78
post Apr 14 2007, 11:56 AM
Wow, sounds like i need to stock up lol. Thats a great deal.
Steve
pa_arora
post Sep 1 2008, 02:48 PM
Drives: 2001 Sonata
QUOTE(duke @ Apr 14 2007, 06:45 AM)
[right][snapback]82961[/snapback][/right]
Hi
I have high NOX on 2001 Sonata V6 and found a TSB to change the O2 sensors. I can change the sensors myself but the issue is how can I re-program the ECM myself? What if I just change and don't reprogram...will I pass the smog in that case?
-p
This post has been edited by pa_arora: Sep 1 2008, 02:48 PM
ssonata78
post Sep 1 2008, 05:24 PM
Hey pa_arora, I would call the dealer to see if they would cover it. It was a TSB and all of my TSB's that afected my car were covered. They told me about the 02 sensors and one failed and according to the TSB/Dealer they would only change the one that failed, they wouldnt change all of them even though the TSB said they were all affected. Basically if it failed the TSB told them to replace only the failed ones.
Steve
pa_arora
post Sep 1 2008, 09:38 PM
Drives: 2001 Sonata
thanks, the dealer in my area sucks, he charges, 115 per hour for diagnostics...i was thinking if change all the sensors myself ..it will still be less..my only concern is ECM programming.
pa_arora
post Sep 2 2008, 01:47 PM
Drives: 2001 Sonata
someone please help me, do i really need to re-program the ECM after changing the sensors? what is the impact if i don't re-program?
pa_arora
post Sep 3 2008, 01:56 PM
Post #11
Drives: 2001 Sonata
bumping...please help!! any help will be appreciated.
pa_arora
post Sep 9 2008, 10:47 PM
Post #12
Drives: 2001 Sonata
okie, posting reply to my own question, since no one here replied. This may help someone else searching for the issue.
I wanted to change the O2 sensors because of the high NOX in Smog problem.
Gave the car for diagnostic to a local mechanic..he said B2S1 oxygen sensor is bad. replaced the sensor witha bosch sensor and did NOT re-programe the ECM.
The car passed with flying colors.
So you do not need to re-programe the ECM, my feeling is re-programming is like a fixpack, which is good to have but not mandatory to have.
hope the car runs well with the Bosch sensor.
No New Posts Oxygen Sensor 2000 Sonata
Bank 2 Sensor 1
1 GuyLydig 268 25th August 2008 - 01:20 AM
Last post by: robtemple
No New Posts Oxygen Sensor Location 02 Accent
P0140 Bank 1 Sensor 2 Which one?
4 silvermount 358 23rd July 2008 - 12:47 PM
Last post by: TommyR
O2 sensor upstream (before converter)
1 litzcan 227 17th July 2008 - 10:34 AM
Last post by: marek46
When to replace
3 Jean 355 23rd June 2008 - 02:32 PM
Last post by: byronguidry3732
No New Posts Oxygen Sensor Problems
3 antoant1 850 30th May 2008 - 05:46 PM
Last post by: Bakwoods
2nd December 2008 - 07:18 PM
