Cracked! |
Apr 9 2007, 09:06 PM
Status:
Drives: Granduer
QUOTE(terkar @ Apr 9 2007, 12:12 PM) I had the same thing happen to a ford contour--they replaced the dash and not a rattle, little things happen, but i wonder if others will have the same problem. [right][snapback]81843[/snapback][/right]
Yep i concur with you on this...depending on whom does the job. My Tiburon had a wrinkle down near the steering shoud...so they replaced the crash pad for me and yes while it was a total pull down...it did not make one rattle post refitment....I was extremely happy and relieved. Dont sweat it ....i know its easy for other forum users to "chill" on the matter but "suck it and see" you might be surprised...you should be as its not monumental by along way. good luck with it.
Apr 16 2007, 08:46 PM
Status:
Drives: Granduer
QUOTE(oztib @ Apr 9 2007, 09:06 PM) Yep i concur with you on this...depending on whom does the job. My Tiburon had a wrinkle down near the steering shoud...so they replaced the crash pad for me and yes while it was a total pull down...it did not make one rattle post refitment....I was extremely happy and relieved. Dont sweat it ....i know its easy for other forum users to "chill" on the matter but "suck it and see" you might be surprised...you should be as its not monumental by along way. good luck with it. [right][snapback]81950[/snapback][/right]
Any news on your dash replacement
Apr 22 2007, 07:48 PM
Status:
Drives: 08 Azera 3.8
QUOTE(heypal @ Apr 8 2007, 03:21 PM) I see you live in Arizona. Could it be you parked it in the sun often and the heat may have caused the crack? What kind of nighttime climate temps did you have when it cracked? Dashboard cracks normally happen during contraction of a dry dash.
Jul 3 2008, 07:45 PM
Expert
Status:
Drives: 07 Azera Ultimate #1, 07 Azera Ultimate #2, 96 Vanden Plas, 97 XJR
QUOTE(LilBean @ Jul 3 2008, 08:13 PM) This is a known issue with some Azeras and Sonatas, but mostly Sonatas. We did so many Sonata dash replacements because of this that at one point we were actually stocking the dash assembly.
It should not squeak or rattle at all after replacement. If it does, take it back and make them fix it. You seem to have a great service dept. that cares about their work so I don't see where you should have any problems. [right][snapback]173988[/snapback][/right]
Lilbean, in your experience, do the replacements tend to come back in for re-replacement? Or are the replacement parts generally "right"?
