 Hyundai-Forums.com > Hyundai Models > Terracan Forum
> Intermittant Hesitation
chyperie
post Mar 27 2007, 12:21 PM
Drives: 2004 Hyundai Terracan
Hi
My 2004 2.9 diesel terracan occassionally hestitates (feels like the engine is cutting out although no dash lights come on) when changing gear from 1st to 2nd and also occassionally does the same when cruising in 5th gear.
I used to think it only did it with the A/C on but this isn't the case.
Anyone else had this problem? If so what is the solution?
Many thanks
Roelie
post Mar 28 2007, 01:58 PM
Drives: 2004 Hyundai Terracan 2.9CRDi
See my question below as well (nmew owner needs education) - has exactly the same symptoms. Am on the point to service (and change the fuel filter) ...
Roelie
retropete
post Apr 30 2007, 09:34 AM
Drives: reno
check you tyre thread dept front and back, and tyre sizes these need to be exactly the same or else the thw 4 wheel drive get conflicting wheel speeds, to test pull out the fuse for the ABS and 4wd and see does it stop. It normally cause a sensation like a missfire
BobW
post Nov 28 2007, 05:16 AM
Had this problem on my 2004.
usually intermittant, took 5 trips under warrente to sort it out.
What they did in the end i do not know, Holdcroft in Stoke on Trent UK.
Wvick
post Dec 15 2007, 08:29 AM
Drives: Hyundai Terracan 2.9 L CRDi Gl manual
Most likely to be fuel filter, had similar problems.
Cheers WVICK
Hyundaiownersclu...
post Jan 1 2008, 07:15 PM
Drives: Tucson
Its propably foreign material in the system. Can be anything from shot balls in the fuel tank to feul pump vanes blocking the injectors. Have it fault code read first then if there are no problems look at the fuel system
BJL
post Jan 8 2008, 05:59 PM
Drives: Terracan Highlander 2.9 Crdi Manual
Like retropete, I had a slight hesistation under acceleration which was particularly noticeable under acceleration in 2nd gear on a hot day. I opened the air-cleaner box and tapped out the dirt in the air cleaner and sprayed carby cleaner on the air flow sensor and the problem went away. The air flow sensors seems to get dirty fairly easily and doesn't calculate the air flow properly particularly when hot resulting in not enough diesel being injected. The problem never happened when cold.
chyperie
post Feb 19 2008, 12:47 PM
Thanks for the replies.
Interestingly when the dealer had it in it showed no diagnostic codes. Anyway the problem went away for a while after they cleaned the air cleaner although the technician thought it could be a dodgy accelerator switch.
After the 60K service where they virtually replace everything the problem went away completely then resurfaced at 67K miles. It's now gradually getting worse as it approaches the 70K service.
It does seem to point towards an air filter/airflow sensor problem. Hopefully with this addition info they'll be able to sort it.
Question?
When the hesitation occurs do your passengers say it feels like you are braking?
Cheers
Mick
BJL
post Feb 20 2008, 11:49 PM
Mick,
I have never had the hesitation to the extent that the vehicle cuts out or actually looses power. The problem I have felt at times is just a hesitation, more just sensed by the driver then felt by other passengers. Others out here is Oz have had problems with the fuel filter and fuel pump. This is however associated with the engine check light coming on and a complete loss of power.
Sagittaron
post Feb 25 2008, 07:22 PM
Drives: 2006 Hyundai Elantra 2.0HVT
I have this exact same problem. Mainly when i go slower speeds, such as when i turn a corner, as i accelerate out of it, it's like the accelerator does not respond for several seconds. It doesn't matter how hard or soft i press down on it, nothing happens until the engine "kicks in".
QUOTE(chyperie @ Feb 20 2008, 04:47 AM)
[right][snapback]138193[/snapback][/right]
It does with me at the higher speeds, around 4th gear. I lose a moderate amount of speed, about 10kph in a few seconds.
QUOTE(BJL)
I have replaced both fuel and air filters and I still have the problem, but I'll try replacing the fuel pump. I used to get a "check engine" light on but never lost power with it before.
chyperie
post Mar 15 2008, 06:53 AM
Post #11
It seems that the car is in fact braking! I found a thread on an Australian Hyundai forum where someone had exactly the same problem and it was traced to a faulty brake sensor. I told my dealer I had spoken to someone with the same problem and they have now found a faulty brake sensor and are replacing it. Hopefully this will solve the problem
chyperie
post Jul 15 2008, 03:58 AM
Post #12
Just an update, the dealer replaced the brake light switch and the problem is cured!
trev0006
post Aug 12 2008, 02:30 PM
Post #13
Drives: tib
fuel pump
No New Posts Hesitation While Accelerating In 3rd Gear
3 Jungle6 199 27th October 2009 - 11:53 PM
Last post by: Mad_Max_46
1 rada 201 21st August 2009 - 12:21 AM
Last post by: mac1
No New Posts Topic has attachmentsIntermittant Rough Idle Caused By Power Steering Sensor Switch
7 Tedley 337 18th June 2009 - 08:16 PM
Last post by: mamamia
No New Posts Hesitation During Acceleration
7 srq screw 1,544 31st March 2009 - 12:27 PM
Last post by: ncoic
7 EMM2875 469 23rd March 2009 - 07:46 PM
Last post by: lam1580
20th March 2010 - 09:56 PM
Privacy Statement
