the most likely cause of this squeak is that the brake caliper is sticking slightly and causing the brake pad to rub on the disc. the vehicle needs to be jacked up to make sure that the wheel runs freely,if not the caliper needs to be checked. there is no re-call on this as far as l know, this is a common fault on any make of vehicle. another cause of the squeak could be the wheel bearing but this is far less likely. the washer motor problem is not that uncommon either. if you want to change it yourself you will need to remove the right hand front plastic inner wing sheild to locate the motor, you will then see why the motor fails (because it is exposed to all the elements!)
