| gllund |
Mar 8 2007, 09:10 PM
Drives: 2007 Hyundai Sante Fe 3.3 Status: OFFLINE
| holger40 |
Mar 9 2007, 10:01 PM
Drives: 2007 Santa Fe SE, 1998 Honda Accord Status: OFFLINE
Hey JyRO, looking forward to your post on Monday, you obviously have a lot of insider knowledge we all benefit from.
If you happen to have any insight on the weight rating of the roof rack as well, please share. A while back there was a thread on the topic, and it is clear the load bars are rated at 220lbs (at least in the US, the UK apparently might have different specs, e.g. non-load bearing bars). But I'm curious if the max. weight rating is the same if you were to put on different load bars, say from Thule, that connected to the side rails, then just moved the bars to the back or even removed them.
The reason I ask: I have one of those car top tents which weighs about 100 pounds, so I can mount it on the roof safely since it is under the dynamic load rating, but I could not sleep in it unless it had a static load rating of say 500 lbs. Many times the manufacturer will make a distinction between a static and dynamic load rating.
| Santatime |
Mar 10 2007, 05:26 PM
Drives: 2007 Santa Fe 3.3GL Status: OFFLINE
this is a great post, i was also wanting to remove them, helps a bit w fuel mileage, and for someone like myself into detailing, its a bit of a pita to keep moving them around to wash/wax ect, so just remove the rear caps is all thats required? you said 2 minutes, guessing its super easy then
This post has been edited by Santatime: Mar 10 2007, 05:42 PM
| dallar |
Mar 10 2007, 07:57 PM
Drives: 2007 Santa Fe Ltd, 2007 Azera Ltd. Status: OFFLINE
Santatime,
The hardest part is getting the caps off. You have to use something like a flat head screwdriver making sure the prying end is covered in something soft like a thin piece of cotton toweling. Then you push it in the side of the cap (not the end) and pry up on the cap as you move the instrument farther under the cap. Watch carefully while you're doing this so that you are prying on the cap only, as there is an anchoring point directly under the cap which you do not want to pry on. Takes some force to loosen the two plastic retainers which are located in the middle at the top of the cap. Be very careful not to mar the finish by shielding the painted surfaces with some type of material, i.e. cloth, tape, etc. The two retainers are plastic holders and the caps simply snap on and off these retainers. (Once you do one it will be much easier to understand.) With the caps off you simply pull up on the crossbar locks and manuever the crossbar toward the rear of the vehicle. Once the bar reaches the rear you will have to push down on a retainer located in the rear of the track to allow the bar to come completely off. It's a whole lot easier and quicker than it sounds, believe me.
And, like you, I wanted to remove them to aid with gas mileage + I'm a waxaholic.....much easier to keep the roof area cleaned and waxed.
| JyRO |
Mar 13 2007, 09:56 AM
Drives: 2006 Honda Odyssey Touring Status: OFFLINE
dallar - I took the day off yesterday. Friday when I went out to see how it was done, the line was already shut down. Removing the rear caps is the correct way. And there is a tab on the bottom of the track that must be pushed down to allow the cross bars to finish sliding to the rear. As for the caps, here at the plant, the put the front (meaning toward the front of the vehicle) in position first and then lay the back end down. Then they whomp the back end down and it snaps into position. I'm not sure how difficult it would be to reverse this sequence, but whoever covered it before gave a good discription. QUOTE(holger40 @ Mar 9 2007, 10:01 PM) Hey JyRO, looking forward to your post on Monday, you obviously have a lot of insider knowledge we all benefit from. If you happen to have any insight on the weight rating of the roof rack as well, please share. A while back there was a thread on the topic, and it is clear the load bars are rated at 220lbs (at least in the US, the UK apparently might have different specs, e.g. non-load bearing bars). But I'm curious if the max. weight rating is the same if you were to put on different load bars, say from Thule, that connected to the side rails, then just moved the bars to the back or even removed them. The reason I ask: I have one of those car top tents which weighs about 100 pounds, so I can mount it on the roof safely since it is under the dynamic load rating, but I could not sleep in it unless it had a static load rating of say 500 lbs. Many times the manufacturer will make a distinction between a static and dynamic load rating. Holger - I'll have to look for the weight rating. But I'm not sure what you're asking when you bring up the Thule load bars. Do you mean, could you add more weight to the roof rack if you (possibly) spread the load over 4 bars (2 Thule and 2 OEM cross bars)? That answer, I don't know. The roof rack rating should take into account more than just the rating of the cross bars alone. So putting more the 220 lbs. into the roof itself (through the roof rack) could damage the roof. There will be no way for me to answer that with any certainty. But I would suspect potential damage to the roof if its loaded more than 220 lbs may be a problem.
| holger40 |
Mar 13 2007, 07:32 PM
QUOTE(JyRO @ Mar 13 2007, 10:56 AM) Holger - I'll have to look for the weight rating. But I'm not sure what you're asking when you bring up the Thule load bars. Do you mean, could you add more weight to the roof rack if you (possibly) spread the load over 4 bars (2 Thule and 2 OEM cross bars)? That answer, I don't know. The roof rack rating should take into account more than just the rating of the cross bars alone. So putting more the 220 lbs. into the roof itself (through the roof rack) could damage the roof. There will be no way for me to answer that with any certainty. But I would suspect potential damage to the roof if its loaded more than 220 lbs may be a problem. :liebe011: Thanks for the info JyRO, you're a very valuable member of this board, we're all lucky to have you here. My suspicion is that the crossbars are the limiting factor in the 220lbs weight rating. I'm not sure of the material but they look kind of flimsy. So my hypothesis was if you took off those crossbars and used different ones that mate to the side rails, then perhaps you've now increased the load rating because you've removed the weakest link. When you watch the manufacturing on the line, does it appear that there is adequate support underneath where the side rails are located? Perhaps they are mated directly to the support underneath? (What do they call that, the B pillar?) This post has been edited by holger40: Mar 13 2007, 07:32 PM
| JyRO |
Mar 16 2007, 08:48 AM
QUOTE(holger40 @ Mar 13 2007, 07:32 PM) :liebe011: Thanks for the info JyRO, you're a very valuable member of this board, we're all lucky to have you here. My suspicion is that the crossbars are the limiting factor in the 220lbs weight rating. I'm not sure of the material but they look kind of flimsy. So my hypothesis was if you took off those crossbars and used different ones that mate to the side rails, then perhaps you've now increased the load rating because you've removed the weakest link. When you watch the manufacturing on the line, does it appear that there is adequate support underneath where the side rails are located? Perhaps they are mated directly to the support underneath? (What do they call that, the B pillar?) Crossbars the limiting factor - Perhaps. Picking them up on the line, they are very light weight. As you will notice if you take them off of your vehicle. And because I do not doubt the cross bars are the weakest link, adding the Thules would likely increase the load carrying capacity (but not the rating). Adequate support underneath - Well that's really the question. And that area is not really the B-Pillar. I could draw you a sketch if you were here. This is how it works (as best I can describe with words). The roof is single piece of steel 0.8 mm thick. The roof rails (what the cross bars attach to) are mounted in a "ditch." The ditch is the junction between the roof and side outer. The side outer is 2 or more sheets of steel clam-shelled ... except where the side outer(s) meet the roof. At that location, its only 1 sheet of steel. The roof sheet is on top and gets spot welded in that ditch area to the side outer down the length of the vehicle. Later, paint sealer is ran into this seam to prevent water leak, etc. The point is, the roof is not that strong. It does have roof bows under the 1 sheet of metal to keep it from oil canning, but still not very strong. The side outers are strong, but yet are taken down to a single sheet in the ditch where the roof and outer meet, as well as where the roof rack rail is mounted. So I would be afraid of cantilevering that side outer down with enough weight. I don't know how much weight would be too much. But I would think that up to about 300 lbs equally distributed would not be a problem statically. 300 lbs driving down the road and bouncing down on the load points may be a problem. I really don't have any way of determining max load. BTW - The A, B, C pillars are: Open all 4 doors. The front door hinge is mounted to the A-Pillar, and the A-Pillar continues up the side of the windshield to the roof. The B-Pillar is between the front and rear door. The C-Pillar is just aft of the rear door. - JyRO
| petejlpetejl |
May 30 2007, 09:57 AM
Drives: 2007 Hyundai Santa Fe 2.2 CRTD CDX+ Status: OFFLINE
 Here in the UK we have been told not to use the Hyundai cross bars for weight loading but the rubber strip can safely be cut to allow the existing cross bars to slide forward or attach 3rd party cross bars such as those made by Thule. I have done this in order to carry bicycles on the roof. Regarding the earlier information on removing the cross bars, thanks guys for the advice about removing the rear caps. For those who might need to do this sometime in the future I've included a picture that might help.
| holger40 |
Jun 6 2007, 12:01 PM
QUOTE(dansaaf @ May 30 2007, 06:16 PM) Shame about the UK roofbars, I went for Thule's in the end also... You folks in the UK might be out of luck when it comes to load bearing cross bars, but at least you have third party options. The Thule dealers here in the US apparently don't have a "multi purpose rack system" that they are recommending. All solutions involve using adapters to mount carriers to the load bars themselves, but it sounds like in the UK you can do you own load bars. I would be grateful if you UK guys (dansaf, petejlpetejl, et al) could share some info on what Thule set up you're using, part numbers, is it a gutterless foot pack, etc., pic would be nice as well. Thanks.
Track this topic
Subscribe to this forum
Download / Print this Topic
Link To Us
Similar Threads
Similar Threads
7th September 2008 - 03:25 AM |
