QUOTE(edwin742000 @ Dec 16 2004, 08:56 PM)
Hai All,
I have purchased a second hand XG30 3 months backFirst month it was running very smoothly. Recently when I drive engine stopped automatically while driving 120KM / Hour, I managed to park the car on side. And I tried after 5 minutes engine started and no problems happened. Still I checked with Hyundai service centre they asked me to change the Airflow censor and also changed the Air filter housing (was broken), after a week the same problem came up. This time when the engine went off brake is also jammed while driving. What could be the problem? I have taken this to service center they couldn’t find out the problems. Can you please advice what could be the problem is? Is there is any defective in 99 model XG30?
Thanks & regards..........Edwin
[right][snapback]3724[/snapback][/right]
Could be a problem with the crank angle sensor. I have had two Grandeurs (one standard and one XG) and both have had problems with the crank angle sensor under warranty. Whilst driving or idling the motor would just go dead and either stay dead or start working again.
In some instances, I'd have to pull over and try restarting the engine. Sometimes that worked and sometimes it didn't at all (requiring a tow to the service centre).
Both my Grandeurs were manufactured in 1999 but registered in 2000.
