 Hyundai-Forums.com > Hyundai Models > Azera Forum
3 Pages V   1 2 3 >
> 2007 Steering Wheel Control Retrofit For 2006
boostedfc3s
post Mar 2 2007, 07:04 PM
Expert
Drives: Former Azera Owner
1/10/2008 Edit: I've lost my web hosting for my pictures. If you need pics please PM me and I will send them to you.
Honestly, this is about the simplest and best upgrade you could possibly do if you have a 2006 Azera. It took me literally 5 minutes to do. It took me more time to take the pics and do this write up.
Tools You Need:
1 Average Size Philips Screw Driver
1 Torx Head Size 40 (this is pretty large)
(IMG:http://www.engineeringpeople.com/test/DSC_2499_DxO.jpg)
First off, I'm not liable if you break your car, deploy your airbags, etc, you do this at your own risk. This is a guide only, consult your dealer or other competent mechanic if you aren't comfortable messing around in the air bag area.
Step 1:
Put your key in and bring your steering wheel all the way forward and down to give you more room to work with. You'll have to leave the key in the ignition in the off position to keep the wheel from retracting. At this point I'd recommend disconnecting your battery for safety sake. I did not, but if you're concerned do it. You'll lose all your presets and seat memory settings etc.
Step 2:
Use the #40 torx bit to loosen the screws to the airbag/horn/plastic cover. I cocked my steering wheel slightly in each direction to get more light into the hole and keep the stalks out of the way when loosening the screws. The two torx screws are straight into the holes, perhaps just slightly offset. There is an internal clip on the screws, you can't loosen them too much, so don't worry about losing them.
(IMG:http://www.engineeringpeople.com/test/DSC_2495_DxO.jpg)
(IMG:http://www.engineeringpeople.com/test/DSC_2496_DxO.jpg)
Step 3:
Gently pull the cover out of the way. DO NOT disconnect any wires. This assembly contains your horn, airbag, etc. There is enough cord to rest it gently on your lower portion of the steering wheel.
(IMG:http://www.engineeringpeople.com/test/DSC_2483_DxO.jpg)
(IMG:http://www.engineeringpeople.com/test/DSC_2484_DxO.jpg)
Step 4:
With the cover out of the way, remove the two gold philips head screws holding the controls down. Save the screws for later, you'll need them to reattach the 2007 controls.
(IMG:http://www.engineeringpeople.com/test/DSC_2481_DxO.jpg)
Step 5:
Press down the tab on the bottom right side of the connector and gently pull the controller assembly away from the harness
(IMG:http://www.engineeringpeople.com/test/DSC_2487_DxO.jpg)
(IMG:http://www.engineeringpeople.com/test/DSC_2486_DxO.jpg)
Step 6:
Attach new controls to old harness. The plug is identical and it snaps right in. Align the controls with the two notches on top and put the old screws back in. Tighten them sufficiently, but don't over do it or you could crack the plastic.
Step 7:
If you disconnected your battery, hook it back up for testing. Turn the key to accessory, verify mode, track up, track down, volume up, volume down, and mute all work.
Step 8:
Once you verify the buttons all work its time to put the airbag/horn/cover back on. It helps here if you have the battery disconnected. I honked the horn on accident a few times when aligning and pressing the cover back into place. Move the two screws out of the way as shown.
(IMG:http://www.engineeringpeople.com/test/DSC_2490_DxO.jpg)
(IMG:http://www.engineeringpeople.com/test/DSC_2494_DxO.jpg)
Step 9:
Align the cover, it will seat itself back in place with a little effort. Tigthen the torx screws, when they become tight, give them a little extra turn to make sure they are tight. You don't want your airbag coming off the wheel in an accident.
Step 10:
Once everything is back in place, start up the car, test your buttons, horn, turn the wheel, and make sure your airbag light isn't on. Thats it, you're done. Enjoy not reaching to the radio to change a track.
This post has been edited by boostedfc3s: Jan 10 2008, 10:47 PM
boostedfc3s
Expert
Final Product. I couldn't post all the pics in the first part.
(IMG:http://www.engineeringpeople.com/test/DSC_2498_DxO.jpg)
azeralover
post Mar 3 2007, 12:35 PM
Drives: 2006 Azera 3.8L
Great work! I think every Azera owner that needs this feature should follow along the steps. It helps a lot!
boostedfc3s
post Mar 3 2007, 12:39 PM
Expert
I took my car out for a drive last night to pick up some dvd's at best buy. One thing I noticed, unlike the old controls, the buttons behind the mode/track light up now too.
mwandmw
post Mar 3 2007, 07:08 PM
Drives: 2006 Azera
This is great information, thanks!! How much did the parts set you back from Hyundai? Thanks
boostedfc3s
post Mar 3 2007, 07:54 PM
Expert
I got it here, http://www.dreamka4u.com/m_mall_detail.php...28451b0753664cd
$42.
I'm not sure how much it is from an actual Hyundai Dealer.
This one came from S. Korea, not sure if the part num for US is the same. 96700 3L001B9
boppert1
post Mar 5 2007, 12:51 AM
Drives: 2006 Azera limited w/u.p.; 2003 GMC Envoy XL
awesome work man....I have been planning on ordering this part and was a little leery about removing the AB/horn assembly but this gives me new confidence.
This needs to be moved to a sticky post that stays on top of the azzy forum threads as a DIY section (hint...moderators)
joebagadonuts
post Jun 21 2007, 10:44 PM
Drives: 2006 hyundai azera ltd 3.8
can you also tune the receiver with the "track up/down" buttons or do they only work with the cd player?
Propflux01
post Jun 24 2007, 08:15 AM
Drives: 2006 Sonata V6/2002 Santa Fe
Wonder if this would retrofit into a Sonata...Sure looks the same.
Brazzel
post Jun 24 2007, 08:22 AM
Master Of Reality
Drives: 2006 Azera limited/Ultimate Pkg., 2004 Toyota Solara SLE, 2004 Chevy Colorado Z71 4x4
Awesome....Good stuff man.
But...........You may be hearing from my lawyer. :grin:
Brazzel
post Jun 24 2007, 09:01 AM
Post #11
Master Of Reality
You have sent a secure payment of $42.00 USD to dreamka4u@gmail.com. <~~ Well I did it....ordered. Free shipping even...I'm impressed. Thanks for this info......Unless I'm killed by the airbag.....Then #%%#@ you !!!!
How long did it take to get the part ? I'm ready to rip into it.
Thanks again for the install info and the site. :beer:
jchag
post Jun 26 2007, 06:58 PM
Post #12
Drives: 06 Azera
Ordered mine!!
Brazzel
post Jun 26 2007, 07:17 PM
Post #13
Master Of Reality
QUOTE(jchag @ Jun 26 2007, 06:58 PM)
Ordered mine!!
[right][snapback]94565[/snapback][/right]
What a great upgrade for a great price...$42 total...nothing else...No shipping no handling..no tax. It's only $6 more than that da**ned cabin airfilter ( I just can't let it go) Mine shipped today...Ready do do it.
Geat post :beer:
This post has been edited by Brazzel: Jun 26 2007, 07:24 PM
Brazzel
post Jun 26 2007, 07:21 PM
Post #14
Master Of Reality
QUOTE(Propflux01 @ Jun 24 2007, 08:15 AM)
[right][snapback]94178[/snapback][/right]
You could e-mail the site and ask. ~~~> dreamka4u@gmail.com
mahout
post Jun 27 2007, 06:53 AM
Post #15
Drives: 2006 Azera 3.8 SE, 91 CRX SiR, 04Civic HX, 03 S10, 07 Sentra SE-R, 08 Honda Fit Sport
Sounds interesting but first:
1. what do the 'new' controls have that the 'old' ones don't?
2. The airbag shutoffs should be used; its too expensive to not deactivate the airbag to worry about resetting the presets.
Brazzel
post Jun 27 2007, 06:49 PM
Post #16
Master Of Reality
Here it is ~~> http://www.dreamka4u.com/m_mall_detail.php...28451b0753664cd
Brazzel
post Jun 27 2007, 06:52 PM
Post #17
Master Of Reality
QUOTE(mahout @ Jun 27 2007, 06:53 AM)
[right][snapback]94635[/snapback][/right]
They control changeing the cds & tracks....And changeing the radio stations... + the mute
Brazzel
post Jun 27 2007, 07:23 PM
Post #18
Master Of Reality
I think as long as you disconnect your battery you should be ok. It's just two hex nuts and you don't disconnect the airbag.
Brazzel
post Jun 27 2007, 07:32 PM
Post #19
Master Of Reality
Mine shipped today. Still have to go through my tools to see if I have that size Hex driver.
Was I correct on the functions Boosted ?
And can I have the name of your Lawyer (kidding)
This post has been edited by Brazzel: Jun 27 2007, 07:33 PM
boostedfc3s
post Jun 27 2007, 09:35 PM
Post #20
Expert
i know you can change tracks, seek on the radio, dunno about changing the cd's thogh.
3 Pages V   1 2 3 >
No New Posts 2006 Sonata Abs And Esc Off Lights
9 cheez-e 140 2nd November 2009 - 11:45 PM
Last post by: MiamiLX
No New Posts 2007-2009 Santa Fe Accessories
2 HyundaiLvr87 1,038 2nd November 2009 - 06:21 PM
Last post by: tech1
No New Posts Steering Wheel Audio Controls
Possible to install on '09 Sonata?
1 smoorman 62 1st November 2009 - 10:59 AM
No New Posts 2007 Hyundai Accent, Mp3 Hook Up
7 mike_thoms 109 31st October 2009 - 06:22 PM
Last post by: hoosieraccent
No New Posts Steering Wheel Feel, Upgrade
9 wrighty 545 29th October 2009 - 05:25 PM
Last post by: borderterrier
7th November 2009 - 07:37 PM
Privacy Statement
