> 1987 Excel Bleed Valve For Coolant?
chowderhead
post Feb 19 2007, 08:03 PM
Drives: 1987 Hyundai Excel GLS
Hi,
I'm new to the forum and have already had great luck searching the posts. I have a quick question that maybe someone can easily answer.
I have a 1987 Excel. I changed the thermostat about a year ago with no problems. Okay - my boyfriend did it but I watched and held stuff. ;-)
Anyway, in the last week the car has occasionally been overheating. It has enough coolant but I think there might be air in the line. Is there a bleed valve somewhere? I'm sure my boyfriend would appreciate any suggestions!
THANKS!
montego
post Feb 20 2007, 02:35 PM
GLOBAL MODERATOR
Group Icon
Group: Super Mod
Drives: XG's (2001&2002)
there is no bleed screw, if you have overheating problems you will need to look elsewhere i.e. is the electric fan working, faulty thermostat, blocked radiator, head gasket leaking
BTW welcome to the forums :00000732:
chowderhead
post Feb 21 2007, 02:25 PM
Thanks for the info. I know the fan is working but I'll check out the other things you mentioned.
will
post Mar 2 2007, 06:21 PM
Drives: hyundai excel 1988 3 door
So....... what was it?
chowderhead
post Mar 5 2007, 10:21 AM
Well, I changed the thermostat and it appeared at first to be fixing the problem. But then a couple days later it started to overheat again. I don't have any leaks. I would like to flush the radiator first and then I think we'll check the water pump.
will
post Mar 11 2007, 05:43 AM
remove the radiator cap and start the car. When it reaches the thermostat's tempature, you will see the coolant circulate thru the radiator's filler hole. If it don't circulate, it's a sign that the water pump may be faulty.
chowderhead
post Mar 16 2007, 12:47 PM
Thanks for the suggestion - I'll try that this weekend. My boyfriend said he thought it might be the water pump. We'll find out.
No New Posts Topic has attachmentsFormer Honda Accord Owners That Bought Sonata
11 Huffa 109 18th November 2008 - 06:16 PM
Last post by: HyundaiLvr87
No New Posts For Those Who Said....
Sub-$2 gas would never return...
1 lovemysantafe 41 12th November 2008 - 01:32 PM
Last post by: the munk
No new Topic has attachmentsCoolant By-pass Mod Diy
125 Komptek 3,056 11th November 2008 - 07:38 PM
Last post by: isaac1909
No New Posts Topic has attachmentsCoolant Bypass + Air Inlet Mod
Coolant bypass + air inlet DIY
1 marek46 195 11th November 2008 - 06:36 PM
Last post by: marek46
No New Posts Excel 93 Mass Air Flow Sensor Problem
do I need the mass air flow sensor?
0 lsotto2005 61 6th November 2008 - 12:03 PM
Last post by: lsotto2005
21st November 2008 - 01:58 PM
