There is a reson you need to go that fast. The new Hemi police criusers do 150 Mph. If you have a open bottle in your car or 5 point on your licence youll need your car to make at least 151MPh.
Where is the governor, i need it gone, and i need a Beta 2 to swap in my 1stgen accent. then i nedd to chuck the spare tire and put the battery in back and remove the back saet....basically slim down. Maybe ill get 150MPh, you think. Also i will need a Preist and Lawyer on retainer.
-Stokelife
I just found a way i think. 1st Generation accents speed is monitored by the ecm, but the ecm gets its info from the speedometer in the dash board. According to the chiltons mintenance manual there are 4 quadrants to the speedometer. So if you connect a meter to the speedometer it should swicth on/off 4 times moving the needle from one side to the other.
I havent tried but suspect if these switches can be space out further the ecm will think your going slower than you are.
This post has been edited by Stokelife: Mar 19 2007, 01:27 AM
