As far as when to make the change, from oem oil to syn, you can do it anytime imo, id get the factory oil outta there in the next few 1000km , i had mine first oil change done around 4500km or so, as far as syn go, im all for it :thumbsup: however i have the "free" oil changes for 5yrs, so for now im just sticking w factory oil, and im changing oil as per Hyundai Rec, every 6000KM give or take, certainly if you switch to syn, you can wait longer between changes, I may or may not make the switch, odds are i will at some point
