 Hyundai-Forums.com > Hyundai Models > Entourage Forum > Loud Engine Knocking Noise
 Loud Engine Knocking Noise, My car makes more noise then it should.
ademinski
post Feb 9 2007, 10:36 PM
Drives: 2007 hyundai entourage
Status: OFFLINE
I bought a 2007 hyundai entourage from lee hyundai in fayetteville, nc @ august. It has been in the shop 4 times for the same recurring problem and more. When the car temp heats up and is standing there i a lod knocking noise that sounds like two spoons tapping against one another over and over again. They changed the chain and the oil pump and it is now louder then before the fixed anything. They tell me its the computer adjusting the transmission and engine together.:( yeah right....when a engine makes a noise it is never a normal or good thing at all, there is a problem and they tell me its normal. They even had a district manager from atlanta georgia drive up and tell us the same thing. We drove a loaner car same make and model but diff color and it did not have that same noise and they even brought a second car and no noise. I stood there for 20 minutes both cars cranked side by side and the dealers said see there Its the same and tried to make me believe that it was the same noise when clearly it wasnt. I have a lemon. And not only does the engine make a noise the steering wheel pulls to the side and they adjusted the axles and it still does the same thing, the air bag always comes on saying it is deployed when its not, and the driver side door makes clinking sounds. I have 3 kids and it just seems like this car is about to break down on me in no time. I am just waiting for the district manager to let me know what the dm in california has to say about this problem....but I know one thing this is not normal. Anyone has the same problem please let me know if its normal or not because this is so frustrating. New car, high payment and loud noise...I should of gone to Honda.
User is offlineProfile CardPM
QuoteReply
angieb
post Feb 11 2007, 03:55 PM
Drives: 2001 Hyundai XG-300L
Status: OFFLINE
Probably should have demanded another car. How many miles did it have on it at purchase? I've dealt with them (brought my XG brand new in 2001), and I've sworn that IF I ever buy another Hyundai, it'll be from another dealership. Take heart, there's competition coming across the street. Also, send a nasty gram to the home office or get the "Troubleshooter" involved. I don't think they want negative publicity.
QuoteReply
burnie
post Feb 12 2007, 01:35 AM
Drives: 2007 Hyundai Entourage
Status: OFFLINE
you should qualify for the Lemon Law...3 or more times for the same problem.Check your manufacture warranty book. They want you to call Consumer Affairs at Hyundai and have a Consumer Affairs Rep try to resolve problem... and follow up with BBB autoline. I am in the process myself and this is step one....Corporate will do the same as District manager....blah blah blah and it s normal....also..bring van to local mechanics shop and see if they can confirm noise so you have documentation if you need to go to arbitration.....But you should qualify for Lemon Law!!!
Fellow Lemon Owner.... :w00t:
QuoteReply
afob3
post Feb 12 2007, 08:01 PM
Drives: 07 Entourage / 05 Elantra GT
Status: OFFLINE
does the tapping go away when you turn off the climate control sytem? I have a slight tapping that I traced to the compressor kicking on and off. Certainly nothing incredibly loud but enough to notice if you are listening for it
I wonder if you have a compressor gone bad instead of an actual engine issue.
QuoteReply
wolfcub
post Feb 13 2007, 03:14 PM
Drives: 2006 Hyundai Sonata
Status: OFFLINE
I just wen through the whole BBB process and let me tell you it is a joke!! I have a 2006 Sonata GLS and it has a defect in it that causes a high pithced engine whine. I went to arbitration and won my fight where the Arbitrator said it was not a "characteristic" of the car and told hyundai to fix it. Hyundai did nothing and I went back to the arbitrator and he said that the noise while there did not substantiate a buy back or replacement and that Hyundai did not need to do anything. WHAT A CROCK!!!! Do not waste your time with the BBB, they work for the manufacturer
QUOTE(burnie @ Feb 12 2007, 02:35 AM)
QuoteReply
mj77323
post Feb 15 2007, 02:55 PM
Drives: 1990 Hyundai Excel 4G63Turbo
Status: OFFLINE
Try adding an extra ground wire from the frame to the engine.... :)
QuoteReply
L8erG8er
post Feb 25 2007, 08:52 PM
Drives: 2007 Entourage GLS
Status: OFFLINE
Just wondering, what oil filter is being used in your van now? Reason I ask is I just happened across a TSB from Hyundai about only using a genuine Hyundai oil filter, or engine knock can occur. See below. This TSB is dated in 2005, but I found it in the Entourage bulletins, and it applies to all Hyundai models. Don't know if this helps or not! (This is their story, and they're sticking to it!)
Page 1 of 1
Technical Service Bulletin
Subject USE OF AFTERMARKET ENGINE OIL FILTERS CAUSING ENGINE KNOCKING NOISE
Group ENGINE MECHANICAL
Number 05-20-002
Date JULY, 2005
Model ALL MODELS
CIRCULATE TO: [ ] GENERAL MANAGER
[X] SERVICE MANAGER [X] SERVICE ADVISOR [X] WARRANTY MGR [ ] SALES MANAGER [X] PARTS MANAGER [X] TECHNICIAN
DESCRIPTION:
Some vehicles may experience an engine knock noise with the use of an aftermarket oil filter. Aftermarket oil filters may use different materials, construction and specifications than genuine Hyundai oil filters, which may lead to pressure variations within the engine, thus contributing to an engine knocking noise.
VEHICLES AFFECTED:
All Models
REPAIR PROCEDURE:
Perform an oil change on the vehicle and replace the aftermarket oil filter with a genuine Hyundai oil filter.
WARRANTY INFORMATION:
Normal warranty procedures apply.
This is not a warranty repair.
QuoteReply
rancal
post Mar 2 2007, 10:57 PM
Drives: 2006 Chevy Tahoe 2006 Hyundai Accent
Status: OFFLINE
QUOTE(L8erG8er @ Feb 25 2007, 06:52 PM)
Page 1 of 1
Number 05-20-002
Date JULY, 2005
Model  ALL MODELS
DESCRIPTION:
VEHICLES AFFECTED:
All Models
REPAIR PROCEDURE:
I thought the Entourage comes with a canister filter. Theirs no aftermarket filter for this van yet. :P
QuoteReply
L8erG8er
post Mar 3 2007, 08:36 PM
Status: OFFLINE
just something else to think about.
QuoteReply
directmk
post Mar 22 2007, 10:33 PM
Drives: Entourage 07
Status: OFFLINE
Was wondering if you resolved this issue yet? I too have an 07 Entourage and it has the same engine knock. The dealership is also telling me that it is a "known issue" and that there is no fix for it. :-(
QuoteReply
sonatalove
post Mar 31 2007, 10:48 PM
Post #11
Expert
Drives: 07 sonata manual
Status: OFFLINE
QUOTE(rancal @ Mar 2 2007, 11:57 PM)
Buy like 5 canister oil filters for you entourage at the dealer and ask for discounts since you buy many of them.
Fram announced making canister oil filters for Sonata 3.3L. I'm not sure about for entourage but I would still use geniune filters to make the warranty issue easy.
Don't use aftermarket filters. They won't give you problems but they use less of materials.
Aftermarket oil filters tend to have less surface area than genuine ones.
QuoteReply
directmk
post Apr 3 2007, 09:29 PM
Post #12
Status: OFFLINE
Update, I got mine fixed. They replaced the AC compressor with a newer version (AC compressor 1.2 ;-) and that fixed the problem. Knocking has gone away!
QuoteReply
JEakin
post Apr 7 2007, 12:41 AM
Post #13
Drives: 2007 Entourage Limited
Status: OFFLINE
my air conditioner makes a knocking noise- sounds like an engine knock but goes away when the AC is off. It is slight- It does sound like something is wrong but it is not very pronounced so it could go for 50k miles as far as I can tell.
the oil filter idea is very interesting- doesn't make much sense that aftermarket oil filters in general can be blamed for making an engine sound like it will fail. Sounds like a great way to sell more oil filters.
QuoteReply
JEakin
post Aug 23 2007, 11:47 PM
Post #14
Status: OFFLINE
20000 mile update-
over the last 4000 miles a whining noise developed that sounded like a ford power steering pump. I mentioned it to my dealer, they found a belt pulley bearing was failing.
After replacement the engine sounds more normal than it did when I bought it. the bearing must have been defective. Even startup sounds are normal where they were clattery and knocking before.
QuoteReply
afob3
post Aug 24 2007, 08:53 PM
Post #15
Status: OFFLINE
The tapping the original poster asked about is now one of the known TSB's(Technical Service Bulletins)
QuoteReply
> Link To Us
> Similar Threads
Safe Boost Pressure On Stock Engine?
Forum : 3G (2006+) Accent
AFireryAccent 190 14 Yesterday, 10:57 AM
By: fonque
Remapping Of Trajet 2litre Diesel Engine Ecu
Forum : Trajet Forum
olderbutnotwiser 258 13 Yesterday, 12:53 AM
By: trajetXG
Check Engine Light Issue
Forum : 3G (2001-2006) Elantra
02elantraphanatic 197 11 Oct 9 2008, 11:08 AM
By: 02elantraphanatic
Engine Ping From 2007 Elantra
Forum : 4G (2007+) Elantra
glr58 1,609 15 Oct 8 2008, 08:57 PM
By: marrug
Radio Doesnt Get Loud.
E se 207 10 Oct 8 2008, 08:47 PM
By: marrug
11th October 2008 - 01:48 AM
