 Hyundai-Forums.com > Hyundai Models > Excel Forum (Mitsubishi-Engined) > Excel 93 Engine Swap
raver4lyf
post Feb 9 2007, 04:42 AM
Drives: Hyundai Excel 93
Status: OFFLINE
Hi, i'm just lookin for sum advice as to what engine i could put in my excel 93, its the hatchback model, and would it also be possible to put a turbo....?
Cheers
User is offlineProfile CardPM
QuoteReply
XCL-NUT
post Feb 12 2007, 07:51 PM
Drives: 1992 Hyundai Excel Sprint GS
Status: OFFLINE
Hi. I own a 1992 excel and have actually studying the same thing at the moment and so far I've been told either a turbo starlet engine (whch I don't really want to do since your going down in engine size) or a 4G63T, which apparantly will almost slip straight in. It's the 2.0 litre engine out of Evos, which I'm liking the sound of better. Am studying up more on it at the moment so will keep you posted if I find out any more. It's not exactly a car people swap engines on all the time so I'm glad I found someone who wants to do the same.
This post has been edited by XCL-NUT: Feb 12 2007, 07:53 PM
QuoteReply
raver4lyf
post Feb 13 2007, 07:26 AM
Status: OFFLINE
do you anywhere you can get body kits for those excels??? ive been lookin everywhere... cheers
QuoteReply
XCL-NUT
post Feb 14 2007, 04:44 AM
Status: OFFLINE
Absolutely none. Been looking right into that. They only started making them for the X3 models. The closed I've been told is a Honda Civic kit, which is what I am looking at, it won't need too much modification compared to some other model kits. They're a similar sort of shape. HFM will be modifying mine for me, I've seen they're work and they are quite good.
QuoteReply
mj77323
post Feb 15 2007, 03:06 PM
Drives: 1990 Hyundai Excel 4G63Turbo
Status: OFFLINE
I have a 90 excel that is ready for the 4G63T, aluminum flywheel, stage 3 clutch, and all wiring necessary is being changed. 4g63T will fit. The frame rails from the donor car a 92 Eclipse are the same width and the engine mounts are in the same position. The suspension components were changed last summer (progressive rate springs from INTRAX that lower the front nearly 2 inches and the rear 1.5 inches. The wheels were ordered fom quality tire MB drifter (had to be modified slightly, my son is a CNC programer). The tires are Toyo 205/45 x16. :)
This post has been edited by mj77323: Feb 15 2007, 03:09 PM
QuoteReply
mj77323
post Feb 15 2007, 03:08 PM
Status: OFFLINE
Try looking for Mitsu lancer kits 1993 are virtually identical to 93 Excels :)
QuoteReply
raver4lyf
post Feb 16 2007, 03:47 AM
Status: OFFLINE
hi guys thanks for the information just looking into it now, as i dunno where i can find an engine like that in australia....
i was reading up and it said something bout being an AWD...?
cheers
QuoteReply
XCL-NUT
post Feb 16 2007, 04:06 AM
Status: OFFLINE
I'm from Australia and that's where I've been hearing about this engine. Think it may be a 4wd engine, not too sure. Got a lot more studying to do yet. Not a person who just jumps into things, I've seen too much go wrong with my boyfriends car when he was doing his engine conversion. I've only heard of 1 being done in Australia before, apparantly got into a mag and everything, but he converted his car to all wheel drive to go with the engine. Thank-you mj77323 for the info on the kits too, I'll definitely look into that.
P.S. Where abouts in Australia are you from raver4lyf? Just curious. I'm in Toowoomba, QLD.
This post has been edited by XCL-NUT: Feb 16 2007, 04:08 AM
QuoteReply
raver4lyf
post Feb 16 2007, 05:14 AM
Status: OFFLINE
hey, yeah im looking into alot of things and different options available, i live in perth....
got a bit of work to do on the body of the car yet, currently off the road as it got yellowed stickered *sigh*....
but yeah will keep you's posted.....
i got another question what sort of alternator can i upgrade to, as i got a 3 amp sound system 2x 800w mono and 1 600w 4 channel, cb, scanner, and 2 spotlights?? as i know this is alot of load i was just wondering what i could do and suggestions??
QuoteReply
vulkus
post Feb 28 2007, 05:45 PM
Drives: '92 Excel GLS
Status: OFFLINE
Mitsubishi Express vans (L300's) came out standard with a 2.0Lt 4G63.
Or a 4G64 for the 2.4Lt option. The latter ones are multipoint fuel inj. The older ones are carbies.
A 4G63T is just a 4G63 with a turbo and most likely a bit of decompression work.
QuoteReply
Melanizm
post May 31 2007, 09:09 PM
Post #11
Drives: 1993 Hyundai Excel
Status: OFFLINE
QUOTE(raver4lyf @ Feb 9 2007, 04:42 AM)
Cheers
Check this out >>> Galant VR-4 Engine Swap
This post has been edited by Melanizm: May 31 2007, 09:10 PM
QuoteReply
wheel_of_steel
post Jun 4 2007, 09:07 PM
Post #12
Drives: 1993 Hyundai Excel Sprint
Status: OFFLINE
Yeah, I'm looking into the same thing, but I'm planning on putting in the Alpha II engine from the X3, except with the CAPA supercharger. Unfortunately there is not much info on it. Would it fit? As for the bodykits, the body measurements are very similar... should be able to get a reputable body shop to get it to fit...
QuoteReply
FlamingComet
post Jul 25 2007, 08:24 PM
Post #13
Drives: '93 Lancer coupe
Status: OFFLINE
Hey a 4g63t came on fwd gallants if tht helps any and if u get a chance upgrade injectors fuel pump and lines allow bigger boost on stock turbo and engine.
Standard fuel 14psi tops
standard internals upgraded fuel system can push 25psi+ but wouldn't run tht everyday lolz. handles 20psi as a daily driver no probs.
QuoteReply
dan_d
post Jan 24 2008, 02:16 PM
Post #14
Drives: '94 Excel CX 1.5L
Status: OFFLINE
Hey, did you guys ever have any luck with this swap?
My '94 has developed a major oil leak and i'm contemplating swapping in something a little more fun than the stock 1.5L :)
I've heard the 4G63 needs a little mod work to fit (new engine mount?); i guess there's nothing that will bolt right in? This would be my first swap, so i'm looking for the easiest swap to get me warmed up :)
Dan
QuoteReply
> Link To Us
> Similar Threads
Engine Racing At Idle And Then Dying At Stop Light
jeffjoleen 447 6 Today, 03:45 PM
By: jakecro
Engine Cover Removal
Forum : Genesis
acroplt 15 0 Today, 01:14 PM
By: acroplt
Check Engine And Abs/esc
Forum : 4G (2006+) Sonata
hmr1979 588 12 Today, 01:07 PM
By: babstude
Engine Oil Color
Forum : 3G (2006+) Accent
dillon1970 146 17 Today, 05:52 AM
By: isaac1909
Excel Photo Post
Forum : Excel Forum (Mitsubishi-Engined)
daves94excel 1,854 19 Yesterday, 05:38 PM
By: ali2128
5th September 2008 - 06:26 PM
