Cold Air Vs. Short Ram Intake |
Jan 25 2007, 10:52 PM
Status:
Drives: 01 Accent GSI
So I came across something different on the net the other day. I saw 2 websites both stating that short ram intakes work better than cold air intakes on accents for some reason. Does anyone know if this is true? If so does anyone know if the difference is major?
Sep 17 2007, 06:48 PM
AMSOIL T1 Direct Dealer
Status:
Drives: '07 Accent SR, '08 Santa Fe Limited
Also you only have a 1.6L. Try this out hook up a hose to your vaccum. Test the sucking power, now add more hose and see the differance. Less sucking. This si due to the fact that it's harder to pull high flow of air over a longer span. Now the hot air issue. Create a Ram air tube that will direct the air towards your Short intake. Also a heat shield is a big bonus. This is why the Hyundai Intake is costly, it comes with a heatshield. Not a great one but a shield none the less.
I also took teh time to look at a few things on the Accent, since I owned a 2004. I notice these things.
1. Throttle body is larger adn more straight through. 2. Intake manfold is larger, not sure why. 3. The same part number is on just about everything onthe engine, except for those things that are apparent.
CAI would work if you were Turboing or Superchargingthe car, but just NA stick with SAI and build a Ram air tubing from the fog light up to the filter.
Sep 30 2007, 10:01 AM
Status:
Drives: 2007 Hyundai Accent GS 1.6
So basically speaking the cold air intakes for the accent are not gonna provide that much more in the way of HP or gas mileiage then the K&N stock replacement air filter-is that true? Sorry for the typo
This post has been edited by larry12s: Sep 30 2007, 08:38 PM
Oct 20 2007, 01:40 PM
Status:
I have been running a K&N in my '94 scoupe- and have had no problems in that last 9 yrs-- I used to use castrol- but switched to Mobile one- and just put a K&N in my '07 accent. It has incresaed miliage by about 1 1/2 miles per gallon
Nov 1 2007, 12:12 PM
Status:
Drives: 2007 Hyundai Santa Fe GL 3.3 AWD
QUOTE(crayb @ Oct 15 2007, 03:01 AM) I know for a fact that the K&N filter will set of CEL in some cars because the 02 sensor becomes clogged/corroded with oil. Ray [right][snapback]113858[/snapback][/right]
Ray: IF the K&N sets a CEL its not because the O2's are affected its because over oiling of the filter will on rare occasions deposit oil on the wires of the MAF causing it to read out of range. Very easily cleaned and rectified. I've run K&N filters on carb'ed and injected cars for years and never had a problem. I'll be putting in a K&N into the SF in the very near future. FWIW, Stewart
Nov 3 2007, 06:59 PM
Status:
OK easy boys/girls. To help put some of the arguments to rest I'll post some information. I will not get into a "mine is better than yours discussion" I will post facts about fluids and at request will provide links to this data. All of my answers on Lubricants and Filters are based on independently tested facts and not just "I ran this, I saw that words" I've said it before and I'll say it again, Provide me with independently tested facts and than we can have a "mine is better than yours" discussion. So with that here we go. First here's a little public dirt in the eyes of all other oil manufactures.AMSOIL is "The First in Synthetics" and also the first in quality, protection and performance. Every other oil company in the world was given the chance to object when AMSOIL applied for trademark rights to "The First in Synthetics", yet after 90 days of waiting, not a single one objected! The U.S. Patent and Trademark Officials stated that by claiming that AMSOIL was the first historically, that AMSOIL was also insinuating to be the best (or #1/first) from a quality or performance standpoint. AMSOIL showed the government officials comparison documentation and test data backing up the claim that AMSOIL was also the best. After the government officials notified all other oil manufacturers that AMSOIL was claiming to be the best, not a single other oil company or competitor objected! Not a peep from any of them! I can guarantee you that if any of these competitors and major oil companies had a product better than AMSOIL they would have objected. Ok on with the facts.Amsoil vs. Mobil 1Amsoil vs. 10 other oils.Amsoil air filter informationI can list more but as you can see, I'll back up everything I say/post with documented proof. All tests were done by a independent tester and as you will see the Amsoil vs. 10 others Oils it didn't always win every category but did win over all. Now I'm not going to reply to any non-documents replies, becasue that gets us no where. But I will be happy to provide you or anyone with any information you require to read and review before making any choice of what oil you may use. It ultimately comes down to what you like to buy, it is your money after all.
Nov 3 2007, 07:16 PM
Status:
QUOTE(Komptek @ Nov 3 2007, 08:59 PM) OK easy boys/girls. To help put some of the arguments to rest I'll post some information. I will not get into a "mine is better than yours discussion" I will post facts about fluids and at request will provide links to this data. All of my answers on Lubricants and Filters are based on independently tested facts and not just "I ran this, I saw that words" I've said it before and I'll say it again, Provide me with independently tested facts and than we can have a "mine is better than yours" discussion. So with that here we go. First here's a little public dirt in the eyes of all other oil manufactures.AMSOIL is "The First in Synthetics" and also the first in quality, protection and performance. Every other oil company in the world was given the chance to object when AMSOIL applied for trademark rights to "The First in Synthetics", yet after 90 days of waiting, not a single one objected! The U.S. Patent and Trademark Officials stated that by claiming that AMSOIL was the first historically, that AMSOIL was also insinuating to be the best (or #1/first) from a quality or performance standpoint. AMSOIL showed the government officials comparison documentation and test data backing up the claim that AMSOIL was also the best. After the government officials notified all other oil manufacturers that AMSOIL was claiming to be the best, not a single other oil company or competitor objected! Not a peep from any of them! I can guarantee you that if any of these competitors and major oil companies had a product better than AMSOIL they would have objected. Ok on with the facts.Amsoil vs. Mobil 1Amsoil vs. 10 other oils.Amsoil air filter informationI can list more but as you can see, I'll back up everything I say/post with documented proof. All tests were done by a independent tester and as you will see the Amsoil vs. 10 others Oils it didn't always win every category but did win over all. Now I'm not going to reply to any non-documents replies, becasue that gets us no where. But I will be happy to provide you or anyone with any information you require to read and review before making any choice of what oil you may use. It ultimately comes down to what you like to buy, it is your money after all.[right][snapback]117127[/snapback][/right] Good rhetoric. But to what end and what has this got to do with the topic, "Cold Air Vs. Short Ram Intake"? Not even a subtle try to hijack a thread and promote a business ... and I'm not even a Moderator. Stewart
This post has been edited by MurfsDad: Nov 3 2007, 07:17 PM
Nov 4 2007, 09:12 AM
Community Advisor
Group: Community Advisor
Status:
Drives: 2007 NF Sonata 2.4L
QUOTE(TOOSLO @ Aug 1 2007, 05:21 AM) i might have this back wards so dont quote me ...lol the short ram helps out low end power and the cold air helps out top end power or visa versa the cai makes alitte more hp but its top end there are some dyon sheets on the web that show this.... [right][snapback]100442[/snapback][/right]
Yes, you do have it backwards; :) A long intake runner is desireble for low-end torque, and a shorter one is better for power production at higher RPM's. That is the reason why the XG, JM 2.7, CM 2.7 & 3.3, NF 3.3 and all 3.8 l engines have a by-pass door in the intake manifold (regulated by the ECM), which changes a long intake to a shorter one at higher RPM's for easier and less restrictive airflow into the cylinders.
