QUOTE(johnc @ Dec 8 2004, 03:46 AM)
The flasher in your car is located under the dashboard it's a black box with green text on it, pull this out to reveal three exposed pins, 1st pin 12volt input from indicators, 2nd pin 12 volt out to indicators voltage gate, 3rd pin is ground supply.
You can go to our local autobarn or supercheap auto to get a new flasher. I have developed a new electronic wiper and indicator alert system, that required no replacement as their are no moving parts inside.
JohnC
[right][snapback]3419[/snapback][/right]
thanks ppl
