I had troiuble with my Engine warning light coming on and occaisionally the engine faultered under heavy load (going up large dunes of very fine sand). This was at around 40.000 km. I had been occaissionally running biodiesel of varying mixes since about 5,000 km with no apparent problem. The dealer did a full diagnostic and ran a flushing kit through the injector system. This helped but the issue was not resolved. I eventually decided to change the fuel filter myself...and no problems since. The fuel filter is a very good one and runs very fine filtration so I'm assuming I just glogged up. I now plan to replace the filter as a matter of course every 30,000 km.
You can use the original Hyundai part or the Delphi. Last look in Oz was;
Whole Filter Assembly 313 90H 1952 Original Cartridge 313 90H 1970 There are 2 types one in printed box Or plain box same filter as informed by the spares man HY-AL008M0010 Delphi 31395-H1952 and OK52A13480 = to HDF924
Cheers Brad
