 Hyundai-Forums.com > Hyundai Models > Tucson Forum
> Pcv Valve Replacement In 2005 Tuscon?
broberts20
post Nov 14 2006, 02:29 PM
Drives: 2005 Hyundia Tuscon
I brought my 2005 Hyundai Tuscon to the dealer at 23,000 miles, for an oil change, tire rotation, and a new air filter. They convinced me that since they are changing the air filter, they should change the PCV valve as well. So I said yes, but when I checked the owners manual, it mentioned nothing about a PCV valve. Is this something that needs to be changed, or was the dealer just trying to get some extra money out of me?
Thanks.
broberts20
LowSonoma1999
post Nov 14 2006, 05:54 PM
Drives: '93 GMC Typhoon
QUOTE(broberts20 @ Nov 14 2006, 02:29 PM)
Thanks.
broberts20
[right][snapback]63072[/snapback][/right]
23k miles might be a little early. We recommend changing them at 30k, but it's not absolutely necessary.
enigma
post Nov 18 2006, 05:21 AM
Drives: 2006Hyundai Tucsin LX
I changed the PCV valve at 30K in my Tucson. This part doesn't cost much and the effects can be noticed in the engine performance. I usually do my own Tucson service.
dries.cronje@bet...
post Sep 6 2008, 02:46 PM
Drives: 2005 Tucson 2.0 CRDI
Can you please tell me what a PCV valve is. I also am a keen self servicer on my Tucson.
Kind regards,
Dries
flyted
post Oct 21 2008, 08:21 PM
Drives: Tuscon
Does the 05 2.0L have just a PCV valve or does it have a filter also?
ddix1026
post Oct 22 2008, 08:51 AM
Lonely Commuter
Status: Online
QUOTE(dries.cronje@bethalmail.co @ Sep 6 2008, 03:46 PM)
Kind regards,
Dries
[right][snapback]188398[/snapback][/right]
from Wiki - Positive Crankcase Ventilation valve, or PCV valve, is a one-way valve that ensures continual evacuation of gases from inside a gasoline internal combustion engine's crankcase.
part costs about $5 or $6.. dont know how to replace though.. labor will probably cost you $40 or $50 because that's what mechanics like to do..
dont know why it would need to be replaced at 23k miles though.. or even 30k.. if you change the oil routinely, the PCV valve shouldnt be getting clogged that early...
flyted
post Oct 22 2008, 08:17 PM
Drives: Tuscon
I don't have a manual for my 05 and like to replace the filter portion, some have one some don't, every couple years or 20k miles since I live in a very dusty area. Anything other than a major overhaul or transmission work is a do it yourself issue for me. I did find the license plate bulb locally, it was the more expensive long-lasting version, thats all they stocked, $2.50 a piece.
ddix1026
post Oct 23 2008, 02:28 PM
Lonely Commuter
Status: Online
i assume you got the Sylvania long-lasting bulb then? not a bad idea anyway.. less chance you will have to replace as soon...
flyted
post Oct 23 2008, 07:20 PM
Drives: Tuscon
You are correct, I got the Sylvania long-lasting bulb as thats all they had. Not sure what makes this bulb long lasting as the filament is so small you can barely see it. Its an odd design where Hyundai decided on 2 license plate lights and chose a very non-standard bulb. I believe every other light on the vehicle is standard, easily found and cheap. In any case they came in packs of 2, so should the other one go out and if they really are long-lasting, I'll never have to replace them again.
Funny thing with my last car, didn't have a single bulb go out for 8 years. I then figured its about time some of the others light may start going out also. So I went and bought a spare bulb for every light on the car as I planned on keeping it several more years. You can probably guess the ending, in the 5 more years I owned it, not a single bulb failed. A 13 year old car and only 1 bulb ever needed replacing.
ddix1026
post Oct 24 2008, 10:58 AM
Lonely Commuter
Status: Online
well, knock on wood, we havent had any lights go out on out Tuc yet.. (had since last June)...
my last car (98 Escort ZX2) - i had bulbs going out all the time... actually failed inspection since one of my lights was out that I didnt know about.. had to replace the headlights about 6 times (then again, i did buy SilverStars - which dont last for cr*p) but also 3rd brake light, turn signals, etc, etc)... i actually had an extra set of healdlight bulbs still in the package when i traded that car is - gave them to my sister who used the same ones...
No New Posts Infinity Sound System Hiss
Has anyone found a solution yet?
13 torscotty 109 Today, 07:27 PM
Last post by: jaymyson
No New Posts Intermittant Engine Check Light
11 mickey taker 455 Today, 03:06 PM
Last post by: Hyundaiownersclub
No New Posts Installing New Timing Belt
need help
10 sunsnow 327 10th November 2008 - 06:28 PM
Last post by: byronguidry3732
No New Posts Internal Rear View Mirror Functions
Internal rear view mirror
1 andymort 113 10th November 2008 - 07:58 AM
Last post by: maseace
No New Posts Incessant Fogging Of The Rear Window!
yup.
19 ohsevenwhiteSE 762 7th November 2008 - 07:40 AM
Last post by: ddix1026
20th November 2008 - 09:34 PM
