 Hyundai-Forums.com > Hyundai Models > Tiburon /coupe forum > RD Tiburon/coupe (1996-2001)
> Tuning Options, After I.H.E. --What`s Next?
VALKYRIE YB70
post Nov 18 2004, 09:20 PM
Mod Emeritus
Drives: Modified (180 b.h.p.) `95 Hyundai S-Coupe Turbo SE ....Sadly now sold & replaced with an `04 Alfa Romeo 156 2-litre Veloce! :-http://aol.photobox.co.uk/album/thumbnails.html?c_album=7089276&page=all
O.K. Guys!......over the months to come there will be lots of info. posted on here about basic tuning; which really boils down to engine breathing improvements : often referred to as I.H.E. (intake, headers & exhaust).
Whilst these performance enhancements are easily (but not always inexpensively!) obtained, it is worth rememberlng that, at the same time, THE UPGRADING OF BRAKES & SUSPENSION IS VITALLY IMPORTANT!......I`m sure these necessary improvments will also be covered at length!.
Anyway; once you have fitted your CAI (cold air induction kit), installed that`killer`cat-back stainless steel straight-through exhaust & bolted-on your new headers, most of you will want MORE.....but probably won`t have the means, or knowledge, to go down the Forced Induction path, (meaning turbocharging or supercharging).
If that is the case & you are staying `normally-aspirated`, then this excellent site will fill you in on some of the Stage 2 upgrades possible on the Tiburon`s/Coupe`s.
I.E.
Underdrive Pulleys
Upgraded Clutches
Aluminium Flywheels.... (yes that`s how it should be spelled Yanks!). ;)
Here`s the link :-
My Webpage
Cheers for now,
Nick. :)
davinci
post Feb 15 2005, 03:26 AM
Drives: tiburon or tuscani
hello i'am from belgium i have a tiburon 4l 2000CC 2003 can you tell me wath i can do for more power. :w00t:
ken2000
post Feb 15 2005, 01:28 PM
Drives: '03' 2.0se COUPE
Hi, i would like to improve the cars zip, but would changing the leads to something
like magnacor make any worthwile gain and do the air intakes make a lot noise.
VALKYRIE YB70
post Feb 15 2005, 11:41 PM
Mod Emeritus
Hi & welcome!.
Davinci.........I thought engine modifications to increase power were illegal in Belgium!!.LOL :wink2:
Start by fitting a CAI & then a 56 mm. dia. mandrel-bent cat-back exhaust with a straight-through muffler.
Ken, most people do notice an improvement after fitting a set of 8mm. Magnecor Electrosport leads (wires Yanks!).......treat her to a new set of NGK copper V-Groove plugs at the same time.
You`ll get LOTS of tuning & D.I.Y. info. here :-
Click
CAI`s produce a healthy deep induction roar.........which is really only audible to the driver!.
Cheers,
Nick. :D
ken2000
post Feb 16 2005, 03:07 PM
Cheers for that, do you know the best place to mail order them from, how much etc..?
baraboab
post Jul 28 2005, 03:52 PM
Drives: 2000 Hyundai Tiburon
Hi , I am from Maldives and i'm having a 2000 tib, I am going to go for N/A mod, and i have got the following parts already today, and here are the items with price
Catback including cat converter, sound clip , dyno and silencer - US$720
BBTB 60mm - US$270
Air Ram Intake Manifold - US$800
4-2-1 Header - US$380
Ground Wire Kit - US$65
2-Piston Brake Kit - US$500
ECU Remapping- US$550
Gauges :
a)(Oil temperature gauge
B) Oil pressure gauge
c) Water temperature gauge
d) Volt meter gauge
e) RPM gauge
f) Fuel ration gauge
All gauges for - US$400
Gauge Pods ( pillar mount and dash mount triple pods )- US$40
Coilovers - ( T& P height adjustable )US$1050
pIROBALL MOUNTING USD 250.00
Head Cover gasket - US$25
Radiator Cap PIAA- US$25
All the items i have purchased from shark racing and can you please let me know what else i will require for N/A mod, i want fender flares, HID kit and i need some one to help me what i need additional ) please???
BDPerformaance
post Aug 28 2005, 05:00 PM
Drives: 89 starion
have a full port & polish done to the intake, head(s), exhaust man."if using factory issue manifolds, no work required on aftermarket headers.
255LPH petro pump, upgraded or larger fuel lines, adjustable regulator.
and if you are really into it, nice shinny aluminium suspension components,
crossmembers,engine accessory brackets,etc....
Dragonmp5
post Nov 30 2006, 02:24 PM
Drives: 2000 Hyundai Tiburon 2.0
Does anyone know where I can get an Airram Intake Manifold? Kspec is out and may not get any more.
mattcast1214
post Oct 14 2007, 01:42 AM
Drives: 2001 Hyundai Tiburon
has anyone tried the venom 400 performance chip?
Erikgsi
post Feb 10 2008, 02:45 PM
Expert
Drives: 2007 hyundai accent GS
Remove the backseat. that will help you shed a couple pounds. Remove the powersteering pump thats a couple pounds and frees up a little hp. If you can do without A/c remove that as well as the components that go with it.
Kain223
post Apr 12 2008, 04:31 AM
Post #11
Drives: 1999 Hyundai Tiburon Fx 2.0
well... What CAI would you recommend?
Dragonmp5
post Apr 16 2008, 04:34 PM
Post #12
I'm lookin for a new clutch that is rated around 300hp. Where's a place that has some for a decent price?
No New Posts Tuning Tips?
well?
4 ATARI 722 18th March 2009 - 12:49 AM
Last post by: F1zeeR
No New Posts Options For Alarm
0 danielhsieh 210 12th May 2008 - 02:11 PM
Last post by: danielhsieh
No New Posts Tuning Help
0 MonkeyBoy1983 459 29th June 2006 - 04:36 PM
Last post by: MonkeyBoy1983
No New Posts Tuning My Coupe Help
0 MonkeyBoy1983 425 26th June 2006 - 05:44 PM
No New Posts Tuning And Carbon Fiber
1 Dragonmp5 397 19th February 2006 - 09:48 PM
Last post by: trajetXG
18th March 2010 - 10:38 AM
Privacy Statement
