the drainplug is on the bottom of the trans case, its a big 24mm bolt. Make sure you don't loose the washer when you remove the plug, and clean the magnet on the end of the bolt, its designed to collect gunk from the fluid. Be sure to use Hyundai fluid SPF-III, the generic stuff won't work. It should take about 5 quarts, unless the models you get are different than US-spec models.
