Oil Change, oil filter cap removal |
Sep 15 2006, 08:22 AM
Status:
Drives: azera
to anyone who has changed their own oil , how easy was it to remove the oil filter cap ??????
Nov 16 2006, 12:02 PM
Status:
Drives: 2006 Azera 3.8 SE, 91 CRX SiR, 04Civic HX, 03 S10, 07 Sentra SE-R, 08 Honda Fit Sport
I haven't changed oil yet but i looked at it because it appears to be the only defect I've found in the Azera. Changing the element instead of the cartridge is likely to encourage contamination of oil. There's reasons why the industry went to cartridge filters from filter elements: too many have wiped the case with trashy rags and worse; used solvents which will do seriously bad things to bearings and rings, not to mention gaskets. The design looks like the factory trying to add to shop income instead of customer friendship. You may find an oil filter wrench, strap or fitted,at the local autoparts place that will work to take the cap off BUT DO NOT USE IT TO REINSTALL UNLESS ABSOLUTELY NECESSARY. A little warp may cause the case to leak. and then be careful. THERE ARE NEW GASKETS INVOLVED, ONE LARGE AT TOP AND ONE SMALL AT BOTTOM. The old ones may not be re-used. Be sure to loosen the cap and wait 5 minutes or so while the oil drains from the canister. Have a catch device handy when you pull the element out - it will be soaked royally. The shop manual is not real clear but expect to need a little more than 5.2 quarts of oil. I will add 5 quarts and run the engine for a few minutes; stop, and add whatever the oil stick says I need to find out how much I need. Note there are differences in quanity even between the 'same' egine of one car to another of same make & model. I use 5-20W or 5-30W Mobil 1. For those who think that's a waste, those of us with dynos and have tested hundreds of cars, synthetic oil always shows a power gain of 3 to 4%. That also helps MPG. The rule is: the less you use your engine or the harder you use it the more you need good synthetic oil. cheers FOLLOWUP I have changed oil now. The cap screwed off by hand and tightened by hand. no leakage, pretty much same as with usual filer cartridges. If you wait 10 minutes after loosening the cap to just lay the cap on the 'bucket' there is little mess and what is easily caught. refill to within 3/16 of full mark on the oil stick took 5.5 quarts. Better a little under than any over full mark. Over increases the 'pumping' losses as the engine works to'pump air back and forth under the pistons. A little under - but not much - decreases those losses.(now you now why hipo engines have 'windage trays' to keep oil splashing up under the cylinders.
This post has been edited by mahout: Jan 25 2007, 11:55 AM
Jan 23 2007, 06:23 PM
Status:
Drives: 08 Azera 3.8
QUOTE(MikeNH @ Jan 23 2007, 04:54 PM) Its on top of the motor :D Remove the plastic engine cover (6 10mm bolts) and you'll see a big black cap to the right in the middle of the engine bay, the filter is under this. After crawling around looking for it Sunday, I found what you describe on top on the trans side, but figured I must be mistaken. Under the engine cover no less. Looks like the oil filter was an after thought. That should be real easy . . . . . . TO MAKE A MESS. I already know about the canister style. I'm having flashbacks of my 57 Bel Air, except for the location. I do appreciate the info.
Jan 25 2007, 07:07 AM
Status:
Drives: 2003 Elantra
Mercedes used the same basic idea on their 5 cyl diesels. At least on those engines, if you crack the filter cap, and then drain the oil, all the oil will drain from the cartridge, too. Give it a few minutes and it will lift out w/o a mess. Does Hyundai have 2 sections like Mercedes did? They had a section for full flow filtering, and a seperate section for bypass filtering to get the tiny stuff. Now this was for a diesel, and there is a lot of soot ( carbon) present in diesel oil.
Mar 15 2007, 12:38 AM
Status:
Drives: Granduer
QUOTE(MS Fowler @ Jan 25 2007, 07:07 AM) Mercedes used the same basic idea on their 5 cyl diesels. At least on those engines, if you crack the filter cap, and then drain the oil, all the oil will drain from the cartridge, too. Give it a few minutes and it will lift out w/o a mess. Does Hyundai have 2 sections like Mercedes did? They had a section for full flow filtering, and a seperate section for bypass filtering to get the tiny stuff. Now this was for a diesel, and there is a lot of soot ( carbon) present in diesel oil. [right][snapback]70757[/snapback][/right]
Dont wanna hijack the thread but FYI all Mercs now employ this system.
Jun 21 2007, 10:06 PM
Status:
Drives: 2006 hyundai azera ltd 3.8
i'll tell you what, after crawling under three different cars (that i've owned) for the past two decades to change an oil filter this seems like an answered prayer. i still have to crawl under my truck (okay not really cause i usually take it to the hobby shop on base and it goes on a lift) so having the filter right on top of the engine where it's easily accessible is...well like i said above. a lot cooler to the touch than your typical screw-off filter and, so far a **** lot less messy. daddy likee! :clap:
Jul 23 2007, 11:38 AM
Status:
Drives: 07 Azera LTD-ULT
Oil Filter TSB 05-20-002, be advised [from hmaservice]: Someone may have already posted this but couldn't find it in either the DIY or Sonata forums. Here it is [in case the PDF doesn't attach properly]: DESCRIPTION: Some vehicles may experience an engine knock noise with the use of an aftermarket oil filter. Aftermarket oil filters may use different materials, construction and specifications than genuine Hyundai oil filters, which may lead to pressure variations within the engine, thus contributing to an engine knocking noise. VEHICLES AFFECTED: All Models REPAIR PROCEDURE: Perform an oil change on the vehicle and replace the aftermarket oil filter with a genuine Hyundai oil filter. WARRANTY INFORMATION: Normal warranty procedures apply. This is not a warranty repair.
Jul 27 2007, 11:07 AM
Status:
QUOTE(MikeNH @ Jul 24 2007, 05:25 PM) That TSB only applies to the spin-on style filters, not to the Azera, Entourage or V6 Sonata. [right][snapback]99176[/snapback][/right]
MikeNH, can you please provide add'l info ? The TSB states all years, all models [attached]. Perhaps, you're thinking of TSB 04-20-001 [also attached]..??.. Please advise, thanks. All, Has anyone had any experience with filters manufactured from "PULL" ?
