92 Excel Only Running On 2 Cylinders, My 92 Excel only running on 2 cylinders
| slaterm |
Aug 28 2006, 08:21 PM
Drives: 1992 Hyundai Excell 4 door Status: OFFLINE
Hi, I have had a 92 excel 4 door for a few years now and up untill yesterday it has been running perfectly.
Very suddenly, it started running very rough, as if it were only running on a couple of cylinders.
while the motor was running, i pulled the spark plug leads off one at a time and noted what happened when i removed each plug lead.
It seems that the leftmost two cylinders are not running. I removed the plugs, and they are both clean and dry with no evidence of fouling.
Just to be safe, i replaced all 4 plugs, ignition leads, cap and rotor but unfortunatly this made no difference.
someone suggested it could be a failed "crank angle sensor" but would this not cause problems on all 4 cylinders ?
what should i look at next ?
thanks, Michael
| RobRocketZX7R |
Aug 28 2006, 08:43 PM
Drives: 2004 Tiburon GT/2003 Kawasaki ZX7R Status: OFFLINE
Well mike I would start with getting the head compression checked. Easy to do if you have the tool for it. Is the car getting spark? Try removing the wires from the dead cylinders and sticking a INSULATED screwdriver into the boot. You should see a spark arc from the wire to the screw driver. If the car is fuel injected you could have a bad injector or 2. Remember all a motor needs to run is air, fuel, and spark. If you drive hard you could have internal damage, but you would hear that. Good luck. Get back to me on the issue. As for the crank positioning sensor.......the car wouldn't run due to the fact that the computer wouldn't know where the crank was at, and would simply stall out.
Track this topic
Subscribe to this forum
Download / Print this Topic
Link To Us
Similar Threads
Similar Threads
8th September 2008 - 02:58 AM |
